Barnet Clutch
- Max2022
Barnet Clutch
22 Apr 2006 03:29
Highly recommend it! My plates and springs were worn, so I got this, I accelerate much faster now! And it's not as stiff as I thought it would be!
However after the install : My front wheel shudders and begins losing control after about 5 seconds of riding without my hands on it? Could be my front tire is worn, or maybe the clutch is slowing the bike down too much?
- Lorcan
- Speed Loony
Re: Barnet Clutch
22 Apr 2006 11:38
And why are you riding around no-handed exactly?...
Post edited by: Lorcan, at: 2006/04/22 14:38
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- hwms
Re: Barnet Clutch
23 Apr 2006 09:46
, or maybe the clutch is slowing the bike down too much?[/quote]
?????? can someone explain this to me ??????
- RomSpaceKnight
Re: Barnet Clutch
23 Apr 2006 21:30
I doubt its your clutch. Look at front tire pressure, wear and bearings.
- Max2022
Re: Barnet Clutch
23 Apr 2006 22:00
hwms wrote:
?????? can someone explain this to me ??????[/quote]
When your in gear, and take your hand off the clutch while moving the engine speed catches up with the rear wheel. When your in 5th gear and doing 30mph theres not enough engine load to give you that presumable jerk that lets you pop wheelies at 9k rpm when you drop the clutch, it just cruises forward but slows the bike down a bit putting stress on the front tire because weight is shifting forward. But I doubt it's that.
- Max2022
Re: Barnet Clutch
23 Apr 2006 22:01
To answer the no handed question. It just gets cold! That and the ladies love to see you standing atop a bike at 80mph waving to them with both hands :laugh:
- absolutepat
Re: Barnet Clutch
15 May 2006 22:31
Where'd you buy it from, and how much? If you don't mid saying.
