Power range
- popsido
06 Dec 2010 13:07 - 06 Dec 2010 13:08 #415673
by popsido
Power range was created by popsido
Can anyone tell me where to find a graph or info on the power range of a KZ650 C3?
I want to know what the cruising rpm is for this bike.
It turns 5000 rpm's at 55 now:huh:
Last edit: 06 Dec 2010 13:08 by popsido.
- tinlizzie37
- Thank you received: 1
06 Dec 2010 13:54 #415686
by tinlizzie37
Bob KZ 650 E1, En 450
Replied by tinlizzie37 on topic Power range
Hi Pop, Sounds about like my KZ 650. These engines just like to rev. What you are experiencing is normal. Changing any gear ratio would effect the performance. Bob
- gane
06 Dec 2010 14:21 #415691
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Power range
Pop, My FSM for KZ650 B2/D1A has 2 pages of graphs desesignated to HP & torque at rpm, & driving force at vehicle speed /rpm. I doubt they were ever "honest", but are there. right at the end of SPECIFICATONS (pages 8 &9) man. # 9992?-1007-01 G
- popsido
06 Dec 2010 17:04 #415711
by popsido
Replied by popsido on topic Power range
Thanks
- Becker
- The Doctor Will Rise Again
07 Dec 2010 01:31 #415753
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic Power range
According to the sevice specifaction handbook for 77' - 79' the max hp for the KZ650C3 is 64hp/8,500rpm, U model (U.S. model) 62hp at 8,000rpm, and G model (German model) 67hp at 8,500rpm.
Max torque is 5.8 kg-m at 7000rpm or for the german model 6.1 Kg-m at 7,000rpm.
My point is that if you are running this bike at 5500 RPM then you aren't fully utilizing it's powerband. If I can find my manual I'll send a picture of fuel consumption, Hp, and torque curves.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Becker
07 Dec 2010 02:21 #415754
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Let's see if this uploads. If it does it contains GPz750 maps but they are pretty similar to what the 650 maps look like.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Bluemeanie
- Thank you received: 14
07 Dec 2010 06:26 - 07 Dec 2010 06:29 #415766
by Bluemeanie
Replied by Bluemeanie on topic Power range
Is this what your looking for? By the way, my 650 does 5800rpm's at 70 mph with stock (16/42) gearing. (click on image for larger version)
Last edit: 07 Dec 2010 06:29 by Bluemeanie.
- rstnick
- Thank you received: 377
07 Dec 2010 18:46 #415870
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Power range
Welcome popsido.
I cruise in 4th and 5th gears anywhere from 5000~8500 rpms.
If I drop below 5000, I will usually down shift a gear.
Depends on how clear the road is too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
