Removing camchain tensioner after valve adj. ?
- ratson
06 Dec 2010 02:15 - 06 Dec 2010 15:40 #415595
by ratson
With fire and sword fight will continue...
Removing camchain tensioner after valve adj. ? was created by ratson
Can anyone point me to the right procedure .
On GPZ 1100B2 after valve adjustment do I need to remove cam chain tensioner to put valve cover properly??
It should be the same for KZ 1000J engines too.
Tensioned cam chain is some how in the way with top rubber cam chain guide in the middle of the valve cover....on my old Suzuki GS I didn't have to..
Thanks
Thanks
Last edit: 06 Dec 2010 15:40 by ratson.
- TerryK
- Thank you received: 3
06 Dec 2010 10:34 #415657
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Removing camchain tensioner after valve adj. ?
Are you talking about the idler at between the cams?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- ratson
06 Dec 2010 15:39 - 06 Dec 2010 15:41 #415699
by ratson
Replied by ratson on topic Removing camchain tensioner after valve adj. ?
Last edit: 06 Dec 2010 15:41 by ratson.
- Link14
- Thank you received: 6
06 Dec 2010 21:37 #415736
by Link14
Replied by Link14 on topic Removing camchain tensioner after valve adj. ?
The cam tensioner looks similiar to my 82 kz750's. Last time I adjusted the valves, I just removed the cross-bolt (13116) which allowed the main tensioner bolt to move back when you replace the valve cover.
