Spark plugs
- rsolano
05 Dec 2010 10:00 #415445
by rsolano
1978KZ1000, stock w exception of aftermarket 4 into 1 and air pods
Spark plugs was created by rsolano
I just finished having my 78kz100 refetted with a stage 3 kit, has 4 into 1 exhaust and individual air pods and wanted to know what Hot or cold plugs were best to run on it?? I would appreciate any input
- otakar
05 Dec 2010 10:38 - 05 Dec 2010 10:41 #415448
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Spark plugs
The plugs will stay the same as original. There have been many discussions on plug brand preference. I personally would not run anything besides Denso W24ES-U or Accel 124 with a gap of .040"-.060" with aftermarket coils. Since you have a KZ1000 you have a Dyna ignition I presume and are running Dyna green coils or Accel 140403 3 Ohm coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 05 Dec 2010 10:41 by otakar.
- Thank you received: 2098
05 Dec 2010 11:00 - 05 Dec 2010 11:00 #415455
by Patton
Replied by Patton on topic Spark plugs
rsolano wrote:
Imo, could confidently begin with spark plugs to FSM specs: NGK B8ES gapped .021~.032" (.7~.8 mm), which should prove satisfactory, at least until further performance evaluations on the particular bike at hand....78kz100...what...plugs were best to run on it?....
Last edit: 05 Dec 2010 11:00 by Patton.
- JMKZHI
- Thank you received: 48
05 Dec 2010 11:45 #415459
by JMKZHI
Replied by JMKZHI on topic Spark plugs
otakar wrote:
If so, what's the knock against NGKs?
PS: this is the second time within the past month that the use of NGKs has been called into question. The other poster from another forum is an experienced Kaw guy.
This sorta implies that NGK spark plugs would not be a good choice. Correct?... I personally would not run anything besides Denso W24ES-U or Accel 124 with a gap of .040"-.060" with aftermarket coils....
- hocbj23
- Visitor
05 Dec 2010 12:36 #415464
by hocbj23
Replied by hocbj23 on topic Spark plugs
Have 4 bikes,1 Kaw,1 Yammy,2 Triumph-running NGK in all of them.No problems,no complaints.Pick a good plug with the heat range specified for your bike,then dont worry,be happy.Kaw and Yammy are modified.lol.bj
- MFolks
- Thank you received: 540
05 Dec 2010 12:37 #415465
by MFolks
Replied by MFolks on topic Spark plugs
I believe the general opinion is that the quality of NGK sparkplugs has slipped over time. Some are made in the U.S., others still made in Japan.
- otakar
05 Dec 2010 13:20 #415477
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
While I was racing back in the late 70s NGK plugs never performed the way ND (Denso) plugs performed.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- rsolano
05 Dec 2010 13:32 #415479
by rsolano
Replied by rsolano on topic Spark plugs
Thanks for your input guys.
- otakar
05 Dec 2010 13:45 #415481
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The ACCEL 142 plugs are a updated version of those and the best substitute I have found for the ND plugs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
