- Thank you received: 44
Vintage Rotary Engine TOO COOL
- jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- jeffasaki
You have 3 options
1 Takeoff
2 fly
3 Land (or control your crash)
Id give er a try
No insurance needed
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- turboguzzi
- Thank you received: 72
by rotary you usually mean a wankel as Kawickrice said here
they had the advantage of cooling the motor better by the forced flow over the cyls.
- TerryK
- Thank you received: 3
I had a friend that had an R5 Suzuki Rotary bike in the 70's. Funny sounding bike compared to the inline 4 with a header.
Those were INTERNAL rotary engines, meaning instead of pistons, the rotary engine has a rotor, or rotors. This aircraft engine has pistons.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- TerryK
nice, even if these motors are called radials, or aero radials, not rotaries
They are actually called rotary engines in vintage aircraft circles. A radial engine does not spin on it's crankshaft like a rotary does, the cylinders and block remain fixed and the engine functions much as any internal combustion engine.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Kawickrice
upload.wikimedia.org/wikipedia/commons/a/ab/Radial_engine.gif [/img]
Never knew the difference in the concepts of the different engines. So this would be a radial chopper not a rotary? I am learning here.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- jeffasaki
The one I posted is a rotary the engine turns,the crank is stationary.
Its crazy but its true
Thats the difference
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- baldy110
- Thank you received: 512
- MFolks
- Thank you received: 540
Koga’s Zero
Courtesy of occasional reader pdxjim, the story of a captured Japanese plane that may have helped to change the outcome of the Pacific War:
“The Zero had superior maneuverability only at the lower speeds used in dogfighting, with short turning radius and excellent aileron control at very low speeds. However, immediately apparent was the fact that the ailerons froze up at speeds above two hundred knots, so that rolling maneuvers at those speeds were slow and required much force on the control stick. It rolled to the left much easier than to the right. Also, its engine cut out under negative acceleration [as when nosing into a dive] due to its float-type carburetor.
“We now had an answer for our pilots who were unable to escape a pursuing Zero. We told them to go into a vertical power dive, using negative acceleration, if possible, to open the range quickly and gain advantageous speed while the Zero’s engine was stopped. At about two hundred knots, we instructed them to roll hard right before the Zero pilot could get his sights lined up.
This recommended tactic was radioed to the fleet after my first flight of Koga’s plane, and soon the welcome answer came back: ‘It works!’â€
It was June 1942, seven months into the war, the outcome trembling in the balance. Flight Petty Officer Tadayoshi Koga lost oil pressure after a strafing run during the diversionary attack against Dutch Harbor in Alaska. He attempted to ditch his stricken craft on a divert field, but it flipped over in a bog and he was killed. His wingmen circled overhead, wondering whether they ought to strafe the wreck – and possibly kill their injured friend – or hope that he could free himself for a rescue.
On such small decisions can depend the fates of empires.
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
