missing 3rd and sometimes 4th gear
- merslinger
03 Dec 2010 12:42 #415184
by merslinger
1993 kz1000
missing 3rd and sometimes 4th gear was created by merslinger
when shifting to third especially my 1993 kz1000 misses third and will act like it is in neutral from there if i toe down it will go into third so it gets stuck between 3 and 4.the same happens between 4 and 5. i tried harder shifts softer shifts higher rpm lower rpm thanks for any advice.
1993 kz1000
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
03 Dec 2010 14:57 #415198
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic missing 3rd and sometimes 4th gear
Before you start tearing into the motor or troubleshooting this problem I'd suggest taking the clutch perch/lever, clutch cable, and clutch actuator apart and clean and lubricate them. It might just be the clutch hanging up. Unlikely maybe but imagine how much you'd be kicking yourself if you tore the motor down just to figure out its the clutch actuator.
Besides, it'll take an hour and cost only a can of cable lube. Even if thats not what it is once its all lubed it'll be nice and smooth and you won't have to worry about it.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- larrycavan
- Visitor
03 Dec 2010 19:37 #415230
by larrycavan
Replied by larrycavan on topic missing 3rd and sometimes 4th gear
merslinger wrote:
Possibly a weak detent spring behind the trans cover. Sounds like the shift drum is rotating too far.. to easily. Not expensive to replace nor difficult. Would need new spring and trans cover gasket. Oil will need to be drained as well.
