KZ1000 cam cover installation
- Kapahulu
01 Dec 2010 14:17 #414955
by Kapahulu
2strokeworld.com
KZ1000 cam cover installation was created by Kapahulu
I opened up the cam cover on my '79 KZ1000 LTD yesterday. There was a bit of a squeeze getting it over the cam chain idler assembly, I managed though.
Checked the valve clearance, replaced the gasket and then... had a very hard time getting that cam cover back on! I ended up taking off one coil (right side) to get the fastening nuts out of the way. Also loosened up the carbs and pulled them back, just in case the throttle cable holders were in the way.
In the end, I pushed a little harder than I wanted to but got the cover back on. Bolted it up, no oil leaks.
Is there a secret to getting this cover on and off smoothly?
2strokeworld.com
- muddy1
- 1980 Kz1000 LTD B4
01 Dec 2010 14:55 #414958
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic KZ1000 cam cover installation
remove both coils and carbs, swing the carbs out of the way with the cables atill attatched, pretty much what you already accomplished.....
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
02 Dec 2010 02:08 #415021
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic KZ1000 cam cover installation
Yeah that is a super tight fit in between the top idler assembly and the backbone on the frame. I think if there was a little less paint on my frame and not quite so much chrome on my valve cover it would slip right in....
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
