- Thank you received: 1
Compression Check
- BIGKEVIN
29 Nov 2010 16:18 #414689
by BIGKEVIN
1976 KZ900
2006 ZX6R
Compression Check was created by BIGKEVIN
I have a 1976 KZ900 that I want to do a compression check on. What is the compression supposed to be on this year bike ?
1976 KZ900
2006 ZX6R
- TerryK
- Thank you received: 3
29 Nov 2010 16:28 #414694
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Compression Check
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
