- Thank you received: 1
Compression Check
- BIGKEVIN
29 Nov 2010 15:46 #414682
by BIGKEVIN
1976 KZ900
2006 ZX6R
Compression Check was created by BIGKEVIN
I have a 1976 KZ900 that I want to do a compression check on. What is the compression supposed to be on this year bike ?
1976 KZ900
2006 ZX6R
- MFolks
- Thank you received: 540
29 Nov 2010 15:55 #414683
by MFolks
Replied by MFolks on topic Compression Check
On a new or rebuilt engine, you might see 180 PSI after a good break in. Engines will run at 100 PSI but will have little power.
Before doing a compression check, adjust the valve lash as having an open valve negates any compression testing.
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
29 Nov 2010 16:03 #414684
by lemo32
1979 kz 1000 06 katana 750
Replied by lemo32 on topic Compression Check
I would want to see atleast 120 psi, on every cylinder, and no cylinder having more than a 10 PERCENT difference, 150 would be great, but as long as all cylinders are close you should be o.k.
- BIGKEVIN
29 Nov 2010 16:34 #414696
by BIGKEVIN
1976 KZ900
2006 ZX6R
Replied by BIGKEVIN on topic Compression Check
When checking the compression, are you supposed to have the throttle open or closed ?
1976 KZ900
2006 ZX6R
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
29 Nov 2010 16:35 #414697
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic Compression Check
open
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- BIGKEVIN
29 Nov 2010 16:39 #414699
by BIGKEVIN
1976 KZ900
2006 ZX6R
What would be the difference in the compression between the trottle being opened and closed ?
1976 KZ900
2006 ZX6R
- andy9802gt
29 Nov 2010 16:51 - 29 Nov 2010 16:52 #414703
by andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
my thought on it would be if you don't open the throttle you would not have enough air coming into the chamber to create positive pressure. with the throttle closed and the plugs in it would just evacuate the air in the cylinder creating a vacuum instead of pressure. I could be wrong though...
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Last edit: 29 Nov 2010 16:52 by andy9802gt.
- BIGKEVIN
29 Nov 2010 16:55 #414704
by BIGKEVIN
1976 KZ900
2006 ZX6R
I was just wondering about the difference. I'll check the compression tomrrow. Thanks for the info.
1976 KZ900
2006 ZX6R
- steell
30 Nov 2010 13:49 #414846
by steell
Replied by steell on topic Compression Check
BIGKEVIN wrote:
Depends, but the difference could be as much as 100 psi.
