- Thank you received: 18
'78 KZ1000 engine rebuild
- andy9802gt
- If it tastes that good, eat it yourself.
28 Nov 2010 16:20 #414593
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
'78 KZ1000 engine rebuild was created by andy9802gt
Hi guys this is going to be the first bike motor I've rebuilt and would like some input. I tore the head off today to send to Cavanaugh, ran the number on the piston after wire brushing the carbon off them to find out they're wiseco 10.25:1 1075cc. The number one looks to have some small nicks in the crown of it but all the others look fine. The P.O. did not silicone the o-ring groove around the cam chain tunnel when he put the 1075 in it so I don't think the head gasket ever sealed right found carbon on the gasket surface when it was removed. I'm going to split the cases and replace the bearings and o rings and the cam chain. possibly put in a back cut tranny and weld the crank. re ring the pistons and possibly replace the number one if I need to. have Cavanaugh do their stage one port job with new cams and then put it back together and see what happens. any suggestions from you guys are welcome and appreciated. also going to be running RS 34's on it with pods. Any guesses on power numbers or torque? ideas for gearing on a daily rider?
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Ktm181
- Man made it, so Man can fix it
28 Nov 2010 18:35 #414617
by Ktm181
Replied by Ktm181 on topic '78 KZ1000 engine rebuild
G'day,
LarryC does nice head work so you got hat part covered, he just did mine and i am following similar to what you are thinking. Larry supplied CamMotion Z1 Cams at a very reasonable price along with his head work and valve springs. I am going 1075, Larry's recommended 29 Keihin smoothbores (new),I have undercut (backcut?)ALL gears both acell and decel sides, FULL bearing and seal replacement etc etc. Gearing on the stock motor 15/35 gave me around 4000 revs at 60mph, i am going a little taller with the bigger engine but will return to low gearing once is run in sufficiently. I have been right through the chassis with Koni shocks,racetech springs and gold valves up front, new fork tubes from Z1 Enterprises (Jeff & Bakes rock!)tapered steer head bearings,roller swingarm bearings, new brakes,new this that and the other! Handles a lot nicer than you would think and went reasonably with stock motor (pipe,pods and rejet only), well enough to frighten a few 30 year younger riders on 30 year younger bikes!
YOu cant go wrong with advice from all these guys on hear, champion people all round & LarryC and the Z1Ent guys are just superb and helping with keeping these beautiful beasties alive and ROCKING!
Cheers from the land of Oz,
Kt.
Kt.
- MFolks
- Thank you received: 540
28 Nov 2010 21:40 #414631
by MFolks
Replied by MFolks on topic '78 KZ1000 engine rebuild
I use
www.gearingcommander.com
when changing gear ratio's(new sprockets and chain).
- andy9802gt
04 Dec 2010 13:42 #415318
by andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Replied by andy9802gt on topic '78 KZ1000 engine rebuild
well it;s started. I ordered all the gaskets and seals for the engine today {wanna talk about salty} and also ordered the new steering head bearings, front and rear wheel bearings, going to drop the bodywork off at my painters house in a few minutes, sending the head off to LarryC tomorrow if the UPS store is open, monday at the latest, ordered the new Kerker with comp. baffle, still waiting on the carbs from Sudco{bunch of slow sob's}, taking the bottom half of the motor to the blasters on monday to drop it off. I hope I'm not trying to tackle to much at once on this since it's my first rebuild but I want to be able to ride this thing when the snow melts. Wish me luck...:woohoo:
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
04 Dec 2010 17:48 #415352
by lemo32
1979 kz 1000 06 katana 750
Replied by lemo32 on topic '78 KZ1000 engine rebuild
sounds like christmas came early, damn i jealous, :lol: post some pics so we can see the progress!
- andy9802gt
08 Dec 2010 17:37 #416004
by andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Well, my head got to Larry today and hopefully it will bear the one ray of light in this motor rebuild. I hoped it was going to be so simple as to split the cases verify everything was good put new seals in and be good, but no such luck. I think I'm making a roadtrip to Pearson Racing in Dayton to drop my crank off to be on the safe side. The counter weights have rust on them and I kinda have the feeling that even if I cleaned that all off and got it looking good that my bearings will be damaged. The cases also show signs of the crank walking so I may need to have the thrust bearing replaced. For $480+ parts it may be the best bet, I just don't want to get it back together and then have the crank come apart with the new found power Larry's going to give it.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- andy9802gt
10 Dec 2010 15:11 #416276
by andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
well I took the day off work and drove my sorry butt to Dayton to drop the crank off at Pearson's to have it completely rebuilt. The good news is he said it wasn't in bad shape. he showed me a couple that he was getting ready to ship and from the looks of them that dude does some fantastic work. I'm starting to get excited;)
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- timebomb33
- Thank you received: 10
10 Dec 2010 17:21 #416298
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic '78 KZ1000 engine rebuild
pearson does awesome work i haven't heard anything bad about him. you made a good choice.
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
06 Mar 2011 06:46 #435439
by Stu Pidasole
Replied by Stu Pidasole on topic '78 KZ1000 engine rebuild
update?
The following user(s) said Thank You: Linc
- andy9802gt
06 Mar 2011 08:04 #435468
by andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
I've got the bottom end back together and should have the top end back on it this week. I'm taking it to Tom Sudman so he can show me how to degree the cams this coming weekend and should have it back in the bike by this Sunday. I have to get the caliper rebuild kits and the Tarozzi rearsets and we be ridin'.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
