94 kz1000 police head
- dvjoiner
27 Nov 2010 00:48 #414368
by dvjoiner
94 kz1000 police head was created by dvjoiner
I have a94 kz1000 police with wiseco 10.5-1 pistons APE .436 cams and heavy duty studs This spring I had 2 cam bearning cap bolts breakoff on front right cap and the bearning can out of the housing now i can't keep the bottom bearing in the head keep coming out of head after about 5mins. Is there a cheap and easy fix beside a new/used head or welding up the fit and line boring it?
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
29 Nov 2010 14:33 #414669
by lemo32
1979 kz 1000 06 katana 750
Replied by lemo32 on topic 94 kz1000 police head
sorry but a bit confused, are you saying you heli-coiled the broken bolts, and now having a problem with cam bearings staying under the camshaft?
- kawsakiman
- Thank you received: 6
29 Nov 2010 15:19 #414675
by kawsakiman
Replied by kawsakiman on topic 94 kz1000 police head
it sounds like he broke them and just left it that way to me.
you need to remove the broken bolts and install new one's or it will never stay in there.
you most likely need new cam bearings now as well.
- lemo32
29 Nov 2010 15:38 #414679
by lemo32
Rev" er" to 8 grand dump the clutch and let the rough side drag! :woohoo:
