Engine knocking noise
- Omaha Rider
Any ideas as to what this could be? It's very embarrasing and annoying.
1978 KZ650 SR D
- Omaha Rider
Hey guys, my 78 kz650 SR D makes a noticable knocking and clacking noise when it first starts up cold. At cold, low-RPM idle, it is very noticable, and on the center stand I can feel the knocking vibrating through the ground. Once it warms up, the noise goes away and the motor runs great, until I turn the motor off. Then you can hear it clack and clock as the motor turns off.
I have gotten the cam chain adjusted and it still makes the same noise.
1978 KZ650 SR D
- bountyhunter
- Thank you received: 337
- Omaha Rider
1978 KZ650 SR D
- JR
- Thank you received: 448
- steell
Primary drive chain?? Where is this located?
The primary chain is located in the approximate center of the motor and connects the crank to the secondary shaft that in turn drives the clutch.
- Omaha Rider
cgi.ebay.com/ebaymotors/OEM-Kawasaki-KZ6...&hash=item3ef5716d74
And this fender:
cgi.ebay.com/ebaymotors/KAWASAKI-KZ650-S...&hash=item53e496ad88
On my 78 Kz650 SR D?
1978 KZ650 SR D
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Thank you received: 2098
Can I put this seat:
And this fender:
Am pretty sure that neither of these would fit your 78 Kz650 SR D.
At least not as simple bolt-on replacements.
Fitment would likely entail frame alterations.
Perhaps someone having actual experience with this situation will come along to offer better or different advice.
- Omaha Rider
And this fender:
Really?? So not all 78 kz frames are the same? Damnit! I don't like the fender and giant brick tail light on my current setup. That seat and fender would look soo slick.
1978 KZ650 SR D
If needed, here's how to navigate kawasaki,com:
Click here > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
[Click on image to enlarge view.]
- Omaha Rider
1978 KZ650 SR D
