- Thank you received: 72
gpz porn
- turboguzzi
21 Nov 2010 08:47 - 21 Nov 2010 08:56 #413644
by turboguzzi
gpz porn was created by turboguzzi
came across this on the net, have no idea where this guy got hi rez pics of wayne's bike. site is japanese, will nevertheless try to contact him.
And damn, how did he got a peek inside the motor? All looks very genuine, the hollow cams are impressive. head is canda model, no exhaust air passages
Wonder where is this bike being worked on?
BTW, click to enlarge..
TG
TG
Last edit: 21 Nov 2010 08:56 by turboguzzi.
- turboguzzi
21 Nov 2010 08:48 #413645
by turboguzzi
Replied by turboguzzi on topic gpz porn
- turboguzzi
21 Nov 2010 08:48 #413646
by turboguzzi
- turboguzzi
21 Nov 2010 08:49 #413647
by turboguzzi
- turboguzzi
21 Nov 2010 08:50 #413648
by turboguzzi
- turboguzzi
21 Nov 2010 08:51 #413649
by turboguzzi
- dutchz
- Thank you received: 4
21 Nov 2010 09:37 #413651
by dutchz
1974 Kawasaki Z1
Stock front hub and rear axle.
Replied by dutchz on topic gpz porn
Awesome bike! Hard to tell from just the close ups if it's the real deal or a very nice replica - but I think it's a road going replica. It explains how he has pics of the inside of the motor, and the bike has an ignition key and a speedometer. Other giveaways would be handlebar switches etc... Rainey's race bike also had a dry clutch, exhaust was mounted with springs, and flat slide carbs.
He's definitely built that bike to high spec with some beautiful components.
I believe Yoshi made hollow core race cams?
1974 Kawasaki Z1
- dutchz
21 Nov 2010 09:48 #413652
by dutchz
1974 Kawasaki Z1
Interesting weld up work on the intake side, any idea why that was done?
1974 Kawasaki Z1
- turboguzzi
21 Nov 2010 10:55 #413656
by turboguzzi
the only switch i see is the ignition and if i remeber the story right, it was kind of a nod of muzzy towards the fact the superbikes at that time had to be related to road bikes. still, too many details make it look like the real McCoy, those cams are very one off, eight plug heads, welded up triple clamps, canadian heads, adjustable/milled rear suspension link. If this guy went so far to build his replica, then its really hats off. Even the rust on some of the bolts would suggest that the bike is not new at all. puzzling.
The welding in the intakes was to have more room for the 31/33mm CR carb rubbers that have larger distance between screws. the Cycle mag muzzy built gpz750 had the similar work done there.
TG
TG
- trianglelaguna
- Thank you received: 235
21 Nov 2010 11:43 - 21 Nov 2010 13:38 #413658
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic gpz porn
not that it matters much...this is one heck of a gpz 750....but i had a feeling it was a copy...
here are a few pics of one of the bikes..remember it evolved i believe constantly and was in a state of transition from track to track..
also it was crashed i think and re-done pretty heavily a few times
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 21 Nov 2010 13:38 by trianglelaguna.
- trianglelaguna
21 Nov 2010 11:45 #413660
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
21 Nov 2010 11:46 #413661
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
1976 KZ900
2003 ZX12R
2007 FZ1000
