- Thank you received: 540
My Ultimate 73 Z1
- z1kzonly
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- roy-b-boy-b
- Thank you received: 103
- z1kzonly
It has been on ebay lots of times.
You get it cheaper than $500
- z1kzonly
Looks like a nice build in its day.
- roy-b-boy-b
- Jack
- Thank you received: 7
The first time I saw that bike was at a Prostar event in Florida. The truck was still moving when I jumped out to go have a look when I spotted it in the pits.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- z1kzonly
- z1kzonly
Do you need another frame? Roy
Hey Jack, that looks like the Broadway Kaw alky turbo bike.
I came across the 1260cc big block cylinder from that bike.
Pup milled down the sides of it. It had a lot of meat on it, but no manufacturer's name. Who knows Pup could have welded it all.
It had 1 burned piston, I had MTC match 1 up. Low compression.
I ran it with Andrews 3x cams and 29's on the street!
That was around 1990.
- TerryK
Nice bearing support irishwill!!
The man is a genius!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- racer54
- Thank you received: 114
