Air suction block off plates, 650 versus 550.
- loudhvx
14 Nov 2010 09:44
Corey Clough is trying to get block off plates made for the 550's. I was curious if anyone knows whether the 650/750 plates are the same size/bolt-pattern.
Here's a little drawing of one of the 550 plates.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Rainman
- and a little Kaw shall lead them
Re: Air suction block off plates, 650 versus 550.
14 Nov 2010 15:11 - 14 Nov 2010 15:13
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
Last edit: 14 Nov 2010 15:13 by Rainman.
- loudhvx
14 Nov 2010 17:56
Thanks Rainman.
That's a shame. So close, too, but no go.
1981 KZ550 D1 gpz.
Other links.
Other links.
- thompsonmx100
15 Nov 2010 10:45
I know a guy that might make you a set. He made me a set i throw him business whenever i can. He makes them for the 750/650. his email is Lonnie@drfshop.com. his phone number is 610-404-bike the website is
www.drfshop.com
i just sent him a my covers and he made me a set.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- APE Jay
17 Nov 2010 21:07
We took care of Corry. He sent us a cam cover, and we made the covers. We will have them available for the other 550 guys by next week.
Jay
Jay
- loudhvx
18 Nov 2010 09:29
Awesome, thanks Jay!
1981 KZ550 D1 gpz.
Other links.
Other links.
- otakar
18 Nov 2010 15:23 - 18 Nov 2010 15:24
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought ones for my 1100 from him. They are beautiful, well made and very inexpensive.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Nov 2010 15:24 by otakar.
- loudhvx
30 Nov 2010 10:30 - 30 Nov 2010 11:06
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 30 Nov 2010 11:06 by loudhvx.
- loudhvx
30 Nov 2010 11:04 - 30 Nov 2010 11:12
Update:
KZ550's break down to two basic valve cover types. The KZ550 A1-A3, C, and D use the first generation motor and valve cover design. The KZ550 A4, H, M and F use the later type. The ZX550 uses a valve cover that is like the later KZ type, but the internal reed assembly is different.
The KZ550 valve covers and the ZX550 valve covers use a different method of sealing the plates to the valve cover. The KZ's (at least the A, C, D, H, M and F) use reed cages with integral rubber seals (part 12021-1003 on the diagram). The ZX uses a series of gaskets. I believe the only gasket needed for a block-off plate on the ZX is the 11009B (11060-1064).
The KZD and KZH plate pattern is the same at the mating surface, and the KZH and ZXA share the same plate part number, so all plates should basically be interchangeable. The only difference is the sealing method.
Most likely, all motors could get rid of the reed cages and just use the 11009B (11060-1064) gasket, however the rubber on the reed cages 12021-1008 may seal better since it is more "squishy"
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 30 Nov 2010 11:12 by loudhvx.
