Cam Timing marks
- jbrewer73
Can someone tell me if this is normal to cam marks positioned differently than the manuals instruction?
Thanks in advance.
Attachment cam_pics.doc not found
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- jbrewer73
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- jbrewer73
- keith1
- Thank you received: 2
I am going to follow the book but what i am trying to figure out is why my cams were positioned the way they are in the pic i posted. Before disassembly I used a 17mm wrench, rotated to "T" 1/4, removed the valve cover and took pics of the cam positioning and they looked how you see them in the pics. How did this bike even run is what i am trying to figure out.
they only look like the book every other time around....just follow the manual and you will be fine...
if you had done another 360 degree spin on the before pic, it would have looked just like the book....you re good...
