78 kz1000 having a cam problem need help
  • manover21
  • manover21's Avatar Topic Author
my 78 kz1000
12 Nov 2010 14:47
#412433
I replaced bearing sleeves on my kz1000 set the top front cam down will not sit flat same as for the rear raised on one side how do I get the cams set in place its like the valves are up ,cranked the engine around did nothing
  • manover21
Re: 78 kz1000 having a cam problem need help
12 Nov 2010 20:19
#412473
trying to get my front and rear cam in having a problem with them sitting flush cams are up on one side like valves are holding them up does anyone have any answers
  • timebomb33
  • timebomb33's Avatar
12 Nov 2010 20:24
#412474
push down on the cam cap with your hand enough to get the bolts started then tighten them down evenly and work back and forth between the cam caps evenly make doubly sure of your timing marks and dont panic take your time.do you have a manual.
I THINK MY POWERBAND BROKE
  • TerryK
  • TerryK's Avatar
Re: my 78 kz1000
12 Nov 2010 20:59
#412480
It's because the cam lobes are facing down (valve would be open if the cam was in). Just push down on the cam until you can thread the cap bolts in then tighten as per your shop manual. Make sure the cams and crank are in the proper position to avoid bending the valves.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • TexasKZ
  • TexasKZ's Avatar
13 Nov 2010 08:59 - 13 Nov 2010 08:59
#412519
Like timebomb33 said, be patient and do not over torque the bolts. I believe about 100 IN/LB is plenty.
kzrider.com/index.php?option=com_kunena&...iew&catid=2&id=69457
Last edit: 13 Nov 2010 08:59 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
Re: my 78 kz1000
13 Nov 2010 09:01
#412520
Don't over torque them.
Do we have two threads for the same discussion here??
  • trianglelaguna
  • trianglelaguna's Avatar
Re: my 78 kz1000
13 Nov 2010 12:12
#412540
ah....this one scares me.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • bountyhunter
  • bountyhunter's Avatar
13 Nov 2010 17:43 - 13 Nov 2010 17:44
#412570
That's the spec, but I have read many posts claiming they stripped some at that setting. I torqued mine to 100 I-P but I have a very accurate torque wrench. Be careful not to exceed the spec.
Last edit: 13 Nov 2010 17:44 by bountyhunter.
  • keith1
  • keith1's Avatar
13 Nov 2010 18:25
#412577
clean the threads and bolts real good and dont go bananas on them.....remember, you can always check at your 3k valve adjustment.....they are under constant pressure, they arent gonna back out that much....
