Later model pistons in 1075 block?
- Headly
10 Nov 2010 23:12 #412149
by Headly
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
Later model pistons in 1075 block? was created by Headly
Gday guys,i have a 900 block with 1075 sleeves fitted.
I have heard you can use the later model GPZ1100 pistons if you run a spacer plate to correct compression height?
Does anyone know what year the wrist pins changed size,and what models pistons could be used as a "cheaper" option for a big bore kit when boring out the 1075 block?:huh:
Thanks in advance,cheers:)
- Kraz1
11 Nov 2010 14:21 #412204
by Kraz1
Replied by Kraz1 on topic Later model pistons in 1075 block?
1981 1982 GPZ11 Hundo run 17mm Pins like the '80 and earlier KZ's...
You can go to www.wiseco.com and view the changes etc.
- larrycavan
- Visitor
14 Nov 2010 04:53 #412637
by larrycavan
Replied by larrycavan on topic Later model pistons in 1075 block?
Headly wrote:
That's incorrect. The spacer plate is required to correct wrist pin location difference.
- Headly
14 Nov 2010 23:48 #412834
by Headly
Replied by Headly on topic Later model pistons in 1075 block?
Yeah thats what i meant,(sort off) level deck height i spose
