J Head
- weelzupamc
11 Nov 2010 21:57 #412335
by weelzupamc
Replied by weelzupamc on topic J Head
Zed1015 nailed it on what's involved. But you also have to pull the motor out of that chassis, you'll never get a j head or even a valve cover on or off in that LTD frame. You really need pistons (compression) upgrade if you want to run a j head, cause you will lose roughly 2 points. But to tell you the truth you won't see any difference just swapping a head and using new pistons to maintain the 8 to 1 comp. unless you change carbs, cams etc. and even then those mods move the power peak up in the RPM band, most likely not what you want for a street bike. Best advice is MTC or wiseco 1075 10.5 to 1 kit with K410 cams. Don't forget a new cam chain and manual tensioner! Money well spent IMHO.
- School Teacher
12 Nov 2010 18:01 #412451
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic J Head
I rebuit my whole top end with the engine in? are we still talking kz1000?
1980 kz1000G1
- larrycavan
- Visitor
13 Nov 2010 19:38 - 13 Nov 2010 19:44 #412600
by larrycavan
Replied by larrycavan on topic J Head
APE Jay wrote:
www.flowbenchtech.com/porting/CRH/kz-data.htm
Shaving a GPz head just for the sake of not buying pistons should be a punishable crime
Get some pistons and a mild .400 lift cam.
APE K410 or Cam Motion Z1 will work great on the street without robbing bottom end if you put some compression with them.
The more cam you put to it, the more compression you need to prop up the bottom end. There's just no getting around that.
Have fun Life is short!
It will flow a lot better than your KZ head, ( Larry can chime in with numbers ) but you are not going to like the compression drop. You should run J pistons with a .040 spacer.
Last edit: 13 Nov 2010 19:44 by larrycavan.
