Need for 6 speed transmission or hydraulic clutch?
- studdosy
10 Nov 2010 09:32 #412003
by studdosy
Need for 6 speed transmission or hydraulic clutch? was created by studdosy
Hello people. I'm just curious but is there a high need for 6 speed transmission or/and hydraulic clutch for any KZ/GPz/ZR motorcycles?
I'm sure anybody with 650 cc or higher would like to have another gear.
As for hydraulic clutch retrofit, who makes the best one for KZ/GPZ/ZR 750?
- testarossa
- Thank you received: 82
10 Nov 2010 09:51 #412007
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic Need for 6 speed transmission or hydraulic clutch?
Just curious here. Are you proposing to make a transmission with 6 gears for the 650/750 and 900/1000 bikes?
2004 ZX-10R
Angola, IN
- M357.5
- Kwakas N' lots of em'
- Thank you received: 10
10 Nov 2010 09:54 #412008
by M357.5
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Replied by M357.5 on topic Need for 6 speed transmission or hydraulic clutch?
testarossa wrote:
X2
X2
- steell
10 Nov 2010 20:44 #412129
by steell
Replied by steell on topic Need for 6 speed transmission or hydraulic clutch?
There is already a six speed that will fit the 650/750 motors, the KZ/GPz 550 transmission.
Most people seem to use the GPz900 or Zx9 hydraulic clutch to convert.
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
12 Nov 2010 08:33 #412381
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Replied by hardr0ck68 on topic Need for 6 speed transmission or hydraulic clutch?
86-90 I think (my notes are on my dead laptop) zx600 transmissions will work (they are the same as the kz550)
The bearings on the input/output shaft of the zx750 are the same as the other bikes so I believe (but am not 100% sure) the zx750 transmission will swap in as well, and it has gearing significantly different (lower if I remember correctly) from the zx600/kz550.
1977 kz650 c1
