z1 900 spits oil
07 Nov 2010 17:18 #411545 by Grapes5x
z1 900 spits oil was created by Grapes5x
:woohoo: Help, After replacing thr dyna 3 with a dyna s my bike now keeps spiting oil out the top ofcranks case relife. Any ideas?
07 Nov 2010 17:23 #411546 by Patton
Replied by Patton on topic z1 900 spits oil
If not already done, would check crankcase oil level.
Reported issue likely doesn't relate to the ignition.
Good Fortune! :)
  • DoubleDub
  • Visitor
07 Nov 2010 19:35 #411566 by DoubleDub
Replied by DoubleDub on topic z1 900 spits oil
Good Fortune! :)
Since Patton is a Mod now, I probably don't need to pipe in, but I agree. When I first had my Kz I overfilled it and had similar issues with a oil air box. I got a lecture from the Kawasaki dealership owner when I took the bike in....
08 Nov 2010 05:38 #411598 by Grapes5x
Replied by Grapes5x on topic z1 900 spits oil
I check the oil level and it is low.
08 Nov 2010 06:05 #411600 by Capt America
Replied by Capt America on topic z1 900 spits oil
We're talking about a valve cover, not head gasket, or base gasket correct? Those are a whole other story and only have one cure, heh.:dry:
If so, is there any chance crank vent hose got pinched, or plugged somehow? Since it's not being caused by overfill of oil. Overpressure seems the culprit, unless seal wasn't done properly.
If it is the head or base gasket that explains your oil loss.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
08 Nov 2010 06:27 - 08 Nov 2010 06:28 #411603 by Patton
Am thinking reported issue regards oil spitting from the crank case vent.
Would next sniff-test the crankcase oil for any gasoline odor. And examine physical condition of the oil.
This is to determine or rule out possible dilution of the oil by fuel contamination, which might cause excessive emission from the crankcase breather.
The next suspect could be blow-by from piston/ring/cylinder wear (where a leak-down test would be helpful).
Thanks for the progress reports.
Good Fortune! :)
Last edit: 08 Nov 2010 06:28 by Patton.
08 Nov 2010 06:45 - 08 Nov 2010 06:46 #411605 by Patton
[Click on image to enlarge view.]
Last edit: 08 Nov 2010 06:46 by Patton.
08 Nov 2010 16:47 #411687 by chance
Replied by chance on topic z1 900 spits oil
I salute you my General...
