"J" Cylinder Block same once there isHi-vo chain?
  • Motor Head
  • Topic Author
06 Nov 2010 14:47 #411303 by Motor Head
Once the cylinder block has the Hi-vo chain guide set up, are they basically the same besides 1000 or 1100? I see quite a few for sale but a lot of times there is not a year on the adds, just pictures. Or is there some difference in the guides/ tensioner on the early Hi-vo setup, vrs the later "J" series?
Also what about 17mm vrs 19mm wrist pins, when was the change?
Thanks for the help.
06 Nov 2010 15:00 #411308 by MFolks
Have you read this from Ape Race Parts?
www.aperaceparts.com/tech/techkz1000.html
  • Motor Head
  • Topic Author
06 Nov 2010 15:04 #411311 by Motor Head
Replied by Motor Head on topic "J" Cylinder Block same once there isHi-vo chain?
I have now, thanks again.
06 Nov 2010 15:11 #411313 by MFolks
Another good article about transmission undercutting:
www.aperaceparts.com/transmissions.html
06 Nov 2010 18:01 #411347 by APE Jay
Those folks must be pretty sharp :laugh:
  • Motor Head
  • Topic Author
06 Nov 2010 19:37 #411371 by Motor Head
I am still wondering if the newer block from the police bikes may have some differences. On Kaw.com it shows the old "J" block supersedes. Would there be some up grade to this newer version? Possibly cast with a different fin design for better cooling, is what I was looking for. Maybe they upgraded the casting? Just a curiosity as when there is a supersession, there is a change, usually for the better design.
07 Nov 2010 04:05 - 07 Nov 2010 04:10 #411430 by otakar
The 2005 1000P engine is identical to the 1981J in all aspects excluding carburetor setup, cams, and 530 chain. They even went back to the old stile ignition with the mechanical advance and old stile pickup coils and IC igniter.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 07 Nov 2010 04:10 by otakar.
