APE SSR1015 Engine Kit
06 Nov 2010 08:15 #411190 by dejavoodo41
APE SSR1015 Engine Kit was created by dejavoodo41
I am currently running a Wiseco 1105 kit that was installed by the previous owner with unknown cams. He stated that they weren't stock but didn't have any information on them. There has been some port work on the head. But to what extent is another unknown. My issue is that when ever I take a long ride in hot weather or get caught in traffic it runs hot. I am planning on rebuilding and was considering going back to the standard bore to make it a more streetable here in Florida. I ride this bike pretty much daily and was wondering if this would be a good reliable setup for a daily rider that may see an occasional trip down the track?
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
06 Nov 2010 08:33 #411194 by Old Man Rock
Replied by Old Man Rock on topic APE SSR1015 Engine Kit
Oil cooler?
Makes a difference on open road but won't help much in stop & go type driving.... Unless of course some 12Vdc fans as well....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
06 Nov 2010 08:45 #411197 by dejavoodo41
Replied by dejavoodo41 on topic APE SSR1015 Engine Kit
No cooler as of yet but that is in the plans. I was thinking about possibly seeing if I could make something like this work. www.jegs.com/i/Derale/259/13950/10002/-1
06 Nov 2010 09:01 #411205 by Old Man Rock
Good price @ under $200 for everything included minus the engine mounts...
Here's the numbers I measured pre & post cooler and synthetic oil....
As can be reviewed, a significant change to oil & engine temps in our type of heat indexes... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
06 Nov 2010 09:33 #411221 by T_Dub
Replied by T_Dub on topic APE SSR1015 Engine Kit
Dave, I've actually decided to go cooler-less on the 810. I live in a place where the temp rarely goes above 70. Plus Lorcan says his temps are fine on the turbo sans oil cooler. I'm gonna try it out, I think I know where I can get a decent laser thermometer to test with. My main reason to scrap it is that I dont think it'll fit with my exhaust. But I might still try it.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
06 Nov 2010 09:48 #411235 by Old Man Rock
"I live in a place where the temp rarely goes above 70"....
AZ winter temps all year long.... sweet! :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
06 Nov 2010 09:50 #411238 by T_Dub
All year, hardly. those are the nice days in the summer, average temps year round are around 50-65. Usually hovers in the 30s in winter.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
07 Nov 2010 14:37 - 07 Nov 2010 14:38 #411523 by APE Jay
Replied by APE Jay on topic APE SSR1015 Engine Kit
1105s in stock 1000 sleeves are very thin. We don't like to do them.
When you get the motor down, check the pistons and see if they are still good. That would have a large bearing on what the nest step would be.
You could send them to us to check out for you.
If they are good, consider having the block machined for larger sleeves, such as GPZ1100 / GS Suzuki, etc. with the spigots machined down to fit in your cases.
You would then have plenty of wall thickness, and fresh round bores.
Last edit: 07 Nov 2010 14:38 by APE Jay.
07 Nov 2010 17:18 #411544 by dejavoodo41
That sounds like a plan. Right now I'm trying to weigh my options and figure out what I'm going to need to do.
