- Thank you received: 50
First time GPz1100 valve clearance-timing work. Could use some voice of experience...
- guitargeek
14 Aug 2006 10:27 #69339
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic First time GPz1100 valve clearance-timing work. Could use some voice of experience...
I guess the option of grinding the valve stems to gain clearance is another advantage of having the shims under the buckets...
- Duck
- e vica na i sau na ga
14 Aug 2006 20:22 #69507
by Duck
Replied by Duck on topic First time GPz1100 valve clearance-timing work. Could use some voice of experience...
Another data point on the KZ shims. The Honda shims, cb750 DOHC, did not get softer as the metal came off. IMO it's worth a try if you've got no parts on hand and if you can recognize when you're getting into the softer metal.
I'm CURSED with this 1100 missed ANOTHER block on ebay by $1. I really want to have here ready in two weeks so I can shakedown for a week and then take on a 600 mile RT.
-Duck
-Duck
