First time GPz1100 valve clearance-timing work. Could use some voice of experience...
  • Duck
  • Duck's Avatar Topic Author
  • e vica na i sau na ga
25 Oct 2005 10:24
#4111
Picked up a non-runner 1982 GPz1100 Sunday.
Couldn't wait to see what I got so took day off from home renovations and made a trip to the shop...
PO said he was getting backfire through throttle bodies.
He said, 'Compression was 50-60 on all so I measured the shims clearance and intakes had none but all exhaust were OK.' So far so good.
He said, 'I took one shim out and compression on that cylinder read 180'. OK, so good chance the associated valve isn't burned.
Then he said, 'I moved the Intake cam one tooth'. Huh???
Well I got the valve cover off and sure enough, the intake cam is advanced by one tooth. Rational escapes me.
Here is where things start to go weird, for a guy who has never had one of these apart before.
As I turn her over, the chain seems to sag down between the two cam sprockets and then pop up. Turning clockwise as per manual (unless Japanese clocks run backwards, mugbus anyone?).
I'm thinking, hmmm.... tensioner may not adjusted, Could it be?
Another weirdness is the force required to turn the crank over is not uniform, even though I have all the plugs out. It's not difficult to turn, just easier in some parts of range and a bit tighter each time the cam chain sags.
Anyone have a clue as to what I'm looking at here? Hopefully nothing that's case cracking serious.
I'm going to finish this cup of coffee and go back and set TDC and put the chain on the right correct tooth. Want to check, just in case he moved exhaust instead of intake.
Once that's done, I'll check the clearances and make a run over to the bike shop to see if they have any shims.
Have a quick question re grinding shims if bike shop is lacking an assortment. The manual says do not grind because they might crack. The guy I rent from has a 24" surface grinder with the right wheel in it. He sharpens dog food making machine knives... Should I heed the manual on this or is it OK to grind valve shims?
Advice regarding any caveats for first timer working in thiis area will be appreciated.
I've only got today to work, then I have to work on house until Sat or Sun. Gotta get new bathroom finished.
Thanks,
-Duck...
  • Fendrguy
  • Fendrguy's Avatar
Re: First time GPz1100 valve clearance-timing work. Could use some voice of experience...
25 Oct 2005 10:36
#4116
Nice find, those 1100's are quick.
I wouldnt grind those shims, there only 5 bucks a peaice. since you have to wait on the bike to get the bathroom finished, ya might as well wait for the right shims to come in if you need to order them.
I just bought some for my 650 a while back and found a dealer that does trade ins. he charged me 2.50 a shim. you might want to check out if your local does the same.
best of luck on your bike.
  • wiredgeorge
  • wiredgeorge's Avatar
25 Oct 2005 11:32
#4134
First, don't try operating the bike till you figure out what is going on with the cam chain. Go to the filebase section of this site and in the non-model specific area is a "cam timing how-to for 903/1015 models". I suggest you read it. Keep in mind that the number of links on your chain is different and thus the information will have to be backed up with the use of a manual specific for your bike model. Next DO NOT GRIND valve shims. EVER. It ruins them. Figure out which type your bike has. Jeff Saunders, www.z1enterprises.com carries "kits" containing a sampler for many types of Kawasakis. They are far less buying this way than they would be buying from your dealers. THEN look at the cam chain issue. It MUST NOT be binding where it gathers. If it does, as you noted, it isn't tensioned. Something is either broken or the tensioner isn't working or the chain is flat worn out. I am not sure what type chain is on your bike. On a 900, the chain is fairly inexpensive and can be installed with a master link so you don't have to split the cases to install. I would remove the tensioner completely and inspect it for function and install a new cam chain. If it still bunches, you will have to do some top end disassembly. Once you have the cylinder head off, it is fairly easy to swap the cam chain out.
Soooooo... first correct cam chain issues, then set valve lash and repeat compression check. Don't worry about backfiring as I would expect a bike with this many small issues to backfire. If you get the cam chain sorted out and the valve lash set, and compression is good, then start the bike and most likely ride away...
  • RonKZ650
  • RonKZ650's Avatar
25 Oct 2005 11:58
#4141
Doesn't the GPZ1100 use the hyvo cam chain with the center tensioner mounted to the valve cover? It's been a long time since I owned a GPZ1100, but if this is the case then yes there will be play in the chain between the cams and yes the engine will jerk forward on the intake cam in certain points of rotation. Try pushing down on the chain between the cams as you turn the engine to kind of simulate what the tensioner would be doing after the cover is installed and see how it feels then.
  • craigpuckett
  • craigpuckett's Avatar
25 Oct 2005 12:15
#4147
Ron hit the nail on the head,hi-vo camchain with center tensioner will always do that,also when you replace the valvecover on a hi-vo type chain you have to reset the auto chain tensioner or you will stretch the chain or wear out the chain guide slides.
the hi-vo chains are around 95.00 and you have to split the cases to replace them.
P.S. good score,I wish it were mine.the first thing that would go is the efi. if you do change to carbs you will also need some J1000 sprockets for the cams.
  • wiredgeorge
25 Oct 2005 12:19
#4149
Ron, I think the cam chain tensioner is at the rear of the engine the same as the older KZs. It is an automatic type if memory serves but I am not really positive. I recall it has a pushrod/spring but there is another smaller springloaded rod on the side that governs how much the bigger pushrod moves outward against the rear cam chain guide (piece that puts pressure on the chain to tension it).
  • RonKZ650
  • RonKZ650's Avatar
25 Oct 2005 13:44
#4173
Yes, I should have worded better. The tensioner is the same and mounted on the back of the block just like other KZs. What I mean is instead of the center idler sprocket that sits between the cams used on the older KZs, the GPZ1100 uses a hyvo chain with no center sprocket between the cams. Instead of the sprocket there is a plastic rubbing block mounted to the valve cover and when the cover is installed it accomplishes the same thing by pressing down on the chain between the cams.
  • Doebag UK
  • Doebag UK's Avatar
25 Oct 2005 13:49
#4176
Hi all, the cam chain tensioner is at the rear of the block and is of the non-return type, hence the cross wedge that sits on the side of the tensioner. Inside the cam cover is a cam chain guide but it is not the tensioner. The chain is of Hy-Vo type and requires an engine split to replace it.
Ride safe Doebag
  • Duck
25 Oct 2005 15:15
#4192
I removed the tensioner and reset the exhaust cam.
Yep, Hy-Vo
Yep, guide ,material in top of cam cover. BTW, how much wear on this guide would there have ot be to suspect all the guides. It's clearly scrubbed but is not grooved a bit. When I drag a fingernail across it(lect to right engine sides) there is no noticable change of depth and no ridges. Clock shows 23k miles but title says miles are incorrect.
The manual says it's a non return type tensioner. However, I can push the tension rod in by hand. Have not read manual section on tensioner disassembly. Have to wait until the weekend for more time to work on this. Unless by some sort of intervention form the gods, the bathromm prokect completes sooner than expected
One of the cam caps on the exhaust side was found to be missing a hollow guide pin. I phoned the PO and he thinks it's on his work bench.
Asked him to measure ID, OD, and length and email to me for comparison. Hopefully it's on his bench and not in the engine.
I may pull the oil pan anyway because he does not know where the one missing intake shim is :-(
First he said he took it out to measure compression because there was no clearance. Now he says the bike came to him without it. He never had the bike running so who knows.
One of the exhaust cam caps had a heli-coiled bolt. No big deal, all the others are nice and clean.
Wonder if anyone here ever owned this bike. It lived in Arkansass, moved to Alabamistan but never ran there, and now resides in the peach state.
82 GPz with average to good black repaint on bodywork and poor black repaint on engine. Really nasty dented up kerker head pipes and megaphone without baffle. Suspect they went on the bike in their present condition because they are way nastier than the rest of it.
It is all there. Airbox, snorkles, throttle bodies, and holders in good shape. Huge battery in this thing.
Thanks for help guys. Will post more if progress or questions this weekend.
-Duck
  • wiredgeorge
26 Oct 2005 12:19
#4446
Someone else had posted a nice pic of a GPZ750 model w/hyvo chain (cam shafts) in another thread and I realized you must be talking about the idler assembly and not the tensioner. The cam caps looked meatier on the 750 and the chain just hung there... it was more obvious that slack would have to be taken up from a cover mounted idler... I would someday like to own a GPZ1100... I had a GPZ550 when I was much thinner but it wasn't very exciting except for the looks and Firecracker Red paint... I owned it and an RZ350 at the same time and the RZ got the nod when I wanted to play boy-racer... The GPZ got the nod when I wanted to commute somewhere.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
26 Oct 2005 12:40
#4451
Does it still have the battery with the sensor? If so, baby that battery...it is no longer available w/ a sensor. If not, you have to ground the sensor to quit it from blinking on your display pad. If the PO haas already grounded it, where did he do it?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • wiredgeorge
26 Oct 2005 14:58
#4478
Mcdroid, The OEM replacment battery for a ZG1200B Voyager XII 1987-2003 has the doo-hickey for the battery idiot light on the battey. The battery is pretty common size too. I know they are still available. Perhaps one of these could be pressed into service on a GPZ? If you really need the dimensions, I can meaure mine which is almost new. It is probably more than strong enough as well as the Voyager has more gee-gaws than a GPZ. The first generation Ventures also had this "feature".
