Piston recommendations
31 Oct 2010 18:23 #410190 by Kapahulu
Piston recommendations was created by Kapahulu
My motor doesn't need it but you know how we like to tinker. Just thinking about a rebore for my '79 KZ1000. Maybe a 1075cc kit, it seems to be popular.
How about compression? I see 10.25 - 10.5 on the higher end and 8.5 - 9~something on the lower end. Will a motor ping on regular gas with 10.25 - 10.5 compression? I am thinking of going with the lower compression pistons for safety but also think the extra compression would be great for the midrange.
2strokeworld.com
31 Oct 2010 18:28 #410192 by Old Man Rock
Replied by Old Man Rock on topic Piston recommendations
10.25 is fine on regular/unleaded gasoline....
If you still desire the low to mid range zip.... Throw some .365 lift cams w/a 4-1 exhaust in there as well... ;)
Oh hell, since it's your money.... Throw some 29-31mm Kehin Cr's on there... :evil:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
31 Oct 2010 18:35 #410193 by racer54
Replied by racer54 on topic Piston recommendations
Hell...it's just money...we can always make more! Easy it is to spend other people's money? lol
31 Oct 2010 18:37 #410194 by racer54
OMR...what did you degree those cams in at?
31 Oct 2010 18:45 #410196 by Old Man Rock
Since it was my first CAM degreeing run, 105 Lobe centers on the nose....
Larry has mentioned about a change to 106 on the intakes, 104 on the exhaust...
I'm thinking about it but she's running so damn fine I hate to mess with her.... Just enjoy her for the time being for she truly is an amazing ride as is...
Maybe the next one since I've been through the process and am comfortable with the procedure... ;)
Here's the specs for the WebCam .365....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
31 Oct 2010 23:17 #410218 by Kapahulu
Replied by Kapahulu on topic Piston recommendations
Thanks for the info. I would probably start with a 1075cc rebore and see what happens.
My KZ1000 seems to be healthy but it doesn't exactly knock my socks off with acceleration. Of course I've had some newer bikes - two ZRX's, a Speed Triple that's probably why I don't think this one is fast.
On the other hand, too much power can be a problem. A speeding ticket increases my insurance rates for three years, don't need that.
BTW the KZ is currently running a Kerker pipe, pods with 20 pilots and 120 mains. The carbs are Mikunis off a GS1000. Not sure about the details but I they are VM's, 26mm I think.
2strokeworld.com
  • tachrev
  • Rubber Side Goes Down
01 Nov 2010 05:07 #410227 by tachrev
Replied by tachrev on topic Piston recommendations
What octane are you considering regular?
I was under the impression you had to run 91/93 octane/high test with 10.25:1.
Build Thread
01 Nov 2010 05:42 - 01 Nov 2010 17:03 #410228 by Old Man Rock
There was a discussion about this awhile back...
Here in AZ, can't even find leaded regular any longer... Some of our members posted where still available in their areas... Can't remember what octane they used... Use the search function, maybe find it...
@ 10.25, racing fuel not required is what I was truly indicating....;) Unleaded gasoline...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 01 Nov 2010 17:03 by Old Man Rock.
  • tachrev
01 Nov 2010 06:44 #410232 by tachrev
Here in AZ, can't even find unleaded regular any longer... Some of our members posted where still available in their areas... Can't remember what octane they used... Use the search function, maybe find it...
Got it. Just wanted to make sure everyone was on the same page terminology-wise.
Build Thread
  • DoubleDub
  • Visitor
01 Nov 2010 07:32 #410238 by DoubleDub
Replied by DoubleDub on topic Piston recommendations
Agreed - I believe the generally accepted rating for octane for the upgraded compression is 90+ (Premium). At least Larry says so which is good enough for me.
