sealing an aluminum spacer/gasket
29 Oct 2010 13:51 #409794 by martijn
sealing an aluminum spacer/gasket was created by martijn
Anyone experience with sealing an aluminum gasket between cilinder and crankcase? I'm going to use it as a spacer to get a lower Compression Ratio....(turbocharger that is)
Do I use 2 standard gaskets, silicon sealer, gleu??
martijn
  • DoubleDub
  • Visitor
29 Oct 2010 19:08 #409838 by DoubleDub
Replied by DoubleDub on topic sealing an aluminum spacer/gasket
I don't, but I'm curious about how you are handling any timing differences caused by the spacer, as well as the question you are asking.
  • DoubleDub
  • Visitor
29 Oct 2010 19:09 #409839 by DoubleDub
Also, what engine is this on and what thickness is the spacer? Is it going below the cylinders?
29 Oct 2010 21:07 - 29 Oct 2010 21:09 #409854 by bountyhunter
Replied by bountyhunter on topic sealing an aluminum spacer/gasket
I think a product like 3-Bond or similar is right because they use that to seal engine half cases together without gaskets.
I guess you would have to slot the cams to be able to zero the cam timing onto the mark?
Last edit: 29 Oct 2010 21:09 by bountyhunter.
29 Oct 2010 22:18 #409875 by Tony
Replied by Tony on topic sealing an aluminum spacer/gasket
Having just gone through this with my bike I have a bit of info on this subject. Just make sure you get the proper spacer for your engine. Don't use the one size fits all. Cometic will custom build one for your exact size of sleeve.
I had some issues with this(oil leak from base gasket) and after disassembling/reassembling my engine probably 6 times trying different configurations of spacer and base gasket with a "one size fits all" I ordered the proper one and that fixed the problem.
I have some pics to share if your interested.
30 Oct 2010 06:28 #409904 by Old Man Rock
Replied by Old Man Rock on topic sealing an aluminum spacer/gasket
Here's what Larry and Plum turned me onto.... ;)
TOP Image:
For gaskets and especially in copper gaskets if using...
Due to MRE's milling crapola :angry: I had to double up my cylinder base gasket... Coated both gaskets, both sides, no leaks what so ever... ;)
Middle Image:
Smear a light coat on valve cover gaskets, no leakies... ;) When checking valve clearances, old gaskets come off cleanly and easily... And yes, I replace mine with new gaskets, for $10, hell you bet....
Bottom image:
Split cases.... I also used this under the aluminum head end caps ;) ..... No leakies.
APE, Z1 and especially Schnitz for gaskets....
www.schnitzracingstore.com/catalogs/cata...93304&showprevnext=1
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • larrycavan
  • Visitor
30 Oct 2010 09:01 #409925 by larrycavan
Replied by larrycavan on topic sealing an aluminum spacer/gasket
I know how I'd do it. I know what works for me. I'll just shut up though because I've seen too many times where what works for one guy doesn't work for the next.....then you're an arse because your advice wasn't any good :woohoo:
Most important thing is PREP! Do it right....happiness. Do it wrong :(
30 Oct 2010 12:52 #409957 by martijn
Replied by martijn on topic sealing an aluminum spacer/gasket
its a for a kz1200 and a 750 twin. And I always set lobe centers after overhauling since the cams are non stock. So I geuss I'm save:lol: Using 1,5mm spacer...
  • z1kzonly
30 Oct 2010 23:10 #410031 by z1kzonly
Replied by z1kzonly on topic sealing an aluminum spacer/gasket
Hi Larry, Does permatex still make "Hylomar" they had paste and a liquid spray.
Elmer Trett said that this was the only stuff that would seal the fueler heads. Jim Mangus said the same.
I had some 15 years ago.
Hylomar!
  • larrycavan
  • Visitor
31 Oct 2010 06:56 #410053 by larrycavan
Hylomar!
Google shows it's still available.
