81' Kz 750 with gpz 750 oil pan question
  • kzcafe750_24
  • Topic Author
29 Oct 2010 12:05 #409775 by kzcafe750_24
81' Kz 750 with gpz 750 oil pan question was created by kzcafe750_24
Hey guys,
Have a question about swapping a gpz 750 oil pan on to my kz 750 motor. I was wondering if I need the gpz oil level switch in order to run with the oil cooler and pan on my kz 750? If not is there a way I can block that spot off on my gpz oil pan?
If anybody knows, if they could drop me a line, it would be great.
Appreciate It much,
Thanks
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985...
29 Oct 2010 17:22 #409830 by Nebr_Rex
Replied by Nebr_Rex on topic 81' Kz 750 with gpz 750 oil pan question
no
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
01 Nov 2010 06:49 #410233 by steell
Replied by steell on topic 81' Kz 750 with gpz 750 oil pan question
No you don't need it, and yes it can be blocked off by making a block off plate for it.
  • kzcafe750_24
  • Topic Author
01 Nov 2010 16:06 #410289 by kzcafe750_24
Replied by kzcafe750_24 on topic 81' Kz 750 with gpz 750 oil pan question
Thank You for helping out!
1985...
