KZ400 engine flush?
  • Kitten Tooth
  • Topic Author
29 Oct 2010 06:26 #409726 by Kitten Tooth
KZ400 engine flush? was created by Kitten Tooth
How would i go about flushing out an engine that had tons of water in it? i already drained the oil from the motor and about 6-7 quarts of nastiness poured out, 4 of them being white sludgy goo (oil contaminated by water).. i know there has to be sludge in there still so how would i go about flushing it out? What should i use, just more oil? Also, will water ruin an ACgenerator just by it getting rusty? The water got in through the ACgenerator cover somehow.. probably no gasket.. Alls i know is that the starter clutch wont engage, it just spins.. i know it needs work.. what should i do?
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
29 Oct 2010 07:10 - 29 Oct 2010 07:13 #409738 by Patton
Replied by Patton on topic KZ400 engine flush?
After draining oil and removing filter, could replace drain screw and filter cap, then fill crankcase with WD40 (available in gallon cans).
Don't start the engine.
Okay to briefly rotate engine with electric starter or kick starter, or hand rotate using 17mm nut on end of crank under points cover.
Idea is to slosh the WD40 around to flush internal parts and absorb water.
WD = Water Displacement.
WD40 is also an excellent oil remover. It is not a lubricant.
Then drain really well -- say overnight.
After well-drained, the crankcase should be reasonably clean inside, and moisture-free.
May then refill with new oil and filter as usual.
Wouldn't hurt to hand-rotate, or briefly spin over engine without starting, in order to get the new oil circulating and pre-lubing the internal parts.
There may be better methods, but that's how I would proceed in this situation.
Good Fortune! :)
Last edit: 29 Oct 2010 07:13 by Patton.
29 Oct 2010 07:26 - 29 Oct 2010 07:28 #409739 by Patton
Some motorcycle alternators rely on a little oil from the crankcase for lubrication.
Would examine lubrication diagram (engine oil flow chart) in the FSM.
Could spray some WD40 in this area to displace existing moisture, and leave the alternator cover off during repairs and testing.
Good Fortune! :)
Last edit: 29 Oct 2010 07:28 by Patton.
  • z1kzonly
29 Oct 2010 07:44 #409740 by z1kzonly
Replied by z1kzonly on topic KZ400 engine flush?
I like the WD40 idea too.
Another way of spinning over is take out the plugs, have the back wheel lifted off, centerstand or jacked up, pull the gear shifter up in to 5th gear.
And with plugs out you can rotate everything by hand including the tranny gears.
When you do try and run it throw some Marvels Mystery oil in the crackcase a quart with 2 quarts of cheap oil.
Run that mixture for about 5 minutes and drain that.
Thats what I would do.
Marvels in the gas too. 2oz. to a gallon.
If it runs, go run the hell out of it for about an hour at highway speeds, any leftover moisture will evaporate.
  • Kitten Tooth
  • Topic Author
29 Oct 2010 10:15 #409758 by Kitten Tooth
Replied by Kitten Tooth on topic KZ400 engine flush?
oh dude, that engine is sitting on one of those mover's dollies in my garage:D It doesnt run at the moment but it will when i get the cases flushed out and new oil in there. I plan on throwing this into a riding lawnmower or making my own frame to have a badass gokart.. Ill do this WD-40 thing and then ill kick the hell out of it with that kicker lever. Ill let you guys know what happens..
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
29 Oct 2010 11:15 #409765 by bountyhunter
Replied by bountyhunter on topic KZ400 engine flush?
I would drop the oil pan and clean it out with mineral spirits and/or acetone spray.. If the engine has been sitting, the inside will be gunked up. Wait until you see what's on the inside of the oil pan.:blink:
  • 9am53
  • homebrew, and some bbq
29 Oct 2010 11:35 #409769 by 9am53
Replied by 9am53 on topic KZ400 engine flush?
acetone is great for drying things out. take the oilpan off and squirt some acetone in there. If taking the oilpan off you see everything is rusty and brown you at least will know it's pooched without having to buy the WD40...
