welded advance unit?
28 Oct 2010 18:02 #409665 by 55fbomb
welded advance unit? was created by 55fbomb
I got a decent deal on a used dyna ignition of ebay and the dude sent the whole advance unit instead of just the end with the magnet on it. anyway, the advance unit is welded at full advance. why would someone do this and would it hurt anthing to run it in a stock engine? also, how would i time it with a timing light with it in full advance at idle? i have my stock advance unit i can use, i just wondered if there is a good reason to use the one that is welded at full advance?
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
28 Oct 2010 18:41 #409675 by loudhvx
Replied by loudhvx on topic welded advance unit?
What type of Dyna? Some Dynas use electronic advance so the mechanical advancer must be fixed stationary.
If it's the Dyna S or Dyna III, you will want to use your working advancer. In that case I don't know why he'd weld it full advance... maybe for drag racing? :huh:
  • z1kzonly
28 Oct 2010 19:03 #409681 by z1kzonly
Replied by z1kzonly on topic welded advance unit?
The Unit came from a dragracer.
Drag bike engines use the full advance curve for high RPM.
You need to use your stock unit. At idle there is about 5-7 degrees timing and over 2-2500 RPM the timing is fully advanced to 30-40 degrees depending on years and engines.
29 Oct 2010 04:30 #409715 by 55fbomb
Replied by 55fbomb on topic welded advance unit?
It looks just like the dyna s thats in my cb750 so im assuming thats what it it. i kinda figured i would wanna use the working advance unit, thanks for confirming it.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
