ground clearance80' kz1000ltd
- mummyarms
- Cafe Noir
28 Oct 2010 08:12
this seems to be a common problem. i recently was switching out a frankensteined ker ker for a vance and hines 4-1 drag and when i put on the V&H; the brake lever was sitting perfectly on the header. any suggestions?
82' KZ1000LTD
- Mcdroid
- Gone Kwackers
Re: ground clearance80' kz1000ltd
28 Oct 2010 08:16
If you are speaking of a sidewinder-style V&H pipe, then you have to alter both your rear brake pedal and the right foot peg. There are a number of people on this forum who have made this alteration...someone will chime in.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mummyarms
- Cafe Noir
28 Oct 2010 08:38
i dont think its the sidewinder style
82' KZ1000LTD
- racer54
31 Oct 2010 12:23
Can you post a picture of the bike with the header on it? I agree with Mcdroid...it sounds like a sidewinder if the brake pedal is hitting it or unless the brake pedal isn't installed right. Picture would tell a lot.
- roy-b-boy-b
31 Oct 2010 17:37 - 31 Oct 2010 17:37
If the pipe looks like this,watch out for right turns.
You could cut your brake lever in half and use a horse shoe to go around the bottom of the pipe. :huh:
Last edit: 31 Oct 2010 17:37 by roy-b-boy-b.
- racer54
31 Oct 2010 17:52
This is a street version of a V&H header. Clearance is not a problem with the street or the brake pedal. Which one do you have? This one is a bolt on and the brake pedal works like it should while the above example requires some work to the pedal for it to work...along with a little work to turn right!
- larrycavan
31 Oct 2010 19:13
mummyarms wrote:
"drag" is the key word.... sounds like a sidewinder to me
