Another Head gasket question...
26 Oct 2010 18:31 #409265 by John T
Another Head gasket question... was created by John T
GPZ1100 head gaskets....
Are they all the same? 1100 gpz is a 72mm bore.. j engine... right?
according to the kawasaki website, I am getting different part #'s for each year...
are they all the same, just different part #'s?
1982- 11004-1105
1983- 11004-1104
1984- 11004-1119
:huh:
True Wisdom Only Comes From Pain.
26 Oct 2010 18:41 #409268 by John T
Replied by John T on topic Another Head gasket question...
Another thing ....
What is it with the 1984 GPZ1100???
you go to Bikebandit and search 84 gpz1100 and they show no listing for that year...
I am finding that at a lot of sites...
plenty of listings for 82-83 gpz1100 but no 84
was this a limited year or something?
I'm just wanting to know if the 82-83 1100 is the same engine.. ?
:huh:
  • larrycavan
  • Visitor
26 Oct 2010 21:12 - 26 Oct 2010 21:19 #409329 by larrycavan
Replied by larrycavan on topic Another Head gasket question...
John T wrote:
Another thing ....
:huh:
83 is a revised motor. Larger wrist pins, new head and trans modifications.
83 - 85 motors should be the same but gasket kits are different part numbers for the 84 motor. See below.
82 is pretty much just an 1100cc J with hotter cams and DFI.
81 had injector port locations in the head casting and analog fuel injection setup.
www.flowbenchtech.com/porting/CRH/kz-data.htm
Regarding gaskets, there are 2 listings for gaskets sets for the motors. APE lists 81-83 as one set and the 84 as another set. 84 set costs a bunch more. I'm not sure what's different between the two sets.
Last edit: 26 Oct 2010 21:19 by larrycavan.
