What are the rubber dampers on cylinder for?
  • gd4now
  • Topic Author
  • Denco where did you go?
25 Oct 2010 09:39 #408958 by gd4now
OK a question. What is the purpose of the 6 rubber dampers or plugs that fit into holes on the bottom of the cylinder / jugs on a kz650? In the picture below the part is #4. I just am not sure what the are for, or why they are there. Just trying to learn something.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • trianglelaguna
25 Oct 2010 09:41 #408959 by trianglelaguna
Replied by trianglelaguna on topic What are the rubber dampers on cylinder for?
dampning
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • gd4now
  • Topic Author
25 Oct 2010 09:46 #408961 by gd4now
OK dampning of what?
1977 KZ650 B1
  • trianglelaguna
25 Oct 2010 09:51 #408962 by trianglelaguna
sorry i was just funnin...well others will know the exact answer...
but..... if they are not o-rings where studs/bolts.. and oil come into contact......then they are in between fins???? and in that case it takes a buzz out of the bike that would make it to the riders contact points.. or a pinging out of the idle...but that is just my deduction and i'm sure you guessed that already....
1976 KZ900
2003 ZX12R
2007 FZ1000
25 Oct 2010 10:01 #408964 by loudhvx
Replied by loudhvx on topic What are the rubber dampers on cylinder for?
If I recall, they are for reducing vibration noise from the fins.
25 Oct 2010 11:37 #408975 by MFolks
I believe the dampners are there to reduce the resonation at certain rpm's of the fins. To demonstrate, the next time your bike is at idle, slowly bring the rpm's up, noticing what buzzes or shakes as the engine turns faster, usually hand control levers and foot pegs.
With the fin dampners removed, the engine might have a "Ringing Sound" at highway speeds making your hearing affected.
  • gd4now
  • Topic Author
25 Oct 2010 17:21 #409034 by gd4now
OK thnaks for the input
1977 KZ650 B1
