J model ... 1 piece head gasket?
24 Oct 2010 18:33 #408861 by John T
J model ... 1 piece head gasket? was created by John T
Does anyone know the part # for a 1 piece head gasket for a 1984 GPZ1100 ? 72 mm bore ( stock bore) if one is even available... ?
I have a used 2 piece gasket COMETIC # C8324
but the 2 inner bolt holes on each gasket don't fit around the APE (heavy duty) studs...
I think a 1 piece gasket would do the trick....
True Wisdom Only Comes From Pain.
25 Oct 2010 04:34 - 25 Oct 2010 04:38 #408908 by otakar
Replied by otakar on topic J model ... 1 piece head gasket?
Those are aftermarket parts, supplied by all of the big bore kit makers, such as APE, Wiseco, MTC and so on. They all have their own part #s for them. This is one place you can go to get one.
www.pitstopperformance.com/parts-and-acc...000-and-kz1100-c-1_4
Just tell Joe what you want and he will have it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 25 Oct 2010 04:38 by otakar.
25 Oct 2010 06:12 #408920 by John T
Replied by John T on topic J model ... 1 piece head gasket?
Thanks.
I fired off an email to joe...
his website says they rarely answer the phone... :laugh:
I'm just thinking... with a 1 piece gasket... the stock rubber o-ring in the middle is not used?
possibly fill the o ring hole with hi temp rtv?
also, would any of you know the torque spec. for the smaller head bolts on each outter side of the head? ( they are maybe 10mm)?
looking at the manual.. I only saw the tq spec for the larger head studs/nuts.
those little bolts make me nervous.... they are pretty much the same size as cam cap bolts... :ohmy:
25 Oct 2010 16:14 #409013 by APE Jay
Replied by APE Jay on topic J model ... 1 piece head gasket?
The 2 piece with the i'ring is actually a nicer deal on a stock bore motor. Just get your snips out and trim the gasket to fit our four studs in the center.
25 Oct 2010 16:31 #409018 by John T
Thanks Jay.
