Sealant for carb holders to engine
- gas
19 Apr 2006 11:50
This could go carb or engine forum I suppose, anyway....
I have read several times in the archives about using RTV black to seal the carb holders to the engine. I went through my tubes and eliminated my Permatex 2 form a gasket and the Permatex Red hi-temp was tempting but seems to be more of an outdoor application. The last tube that I have is Permatex ultra grey. It's oil resistant, has serious vibration resistance and a heat resistance up to 650 degrees. Is there any reason why I shouldn't use ultra grey to seal my carb holders instead of the Loctite RTV black, that only goes up to 400 degree heat resistance?
Post edited by: gas, at: 2006/04/19 14:52
- mariozappa
Re: Sealant for carb holders to engine
19 Apr 2006 12:12
I've used the red hi-temp in the past and it's been just fine.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- BARNEYHYPHEN
19 Apr 2006 13:17
I use the Ultra Grey and have suffered no apparent problems. I also smear a little vaseline inside the boots before i refit the carbs. Seems to help the refit process.
- jtmcculloch
19 Apr 2006 16:01
Ultra Grey is the best
you can also mix in some thinner and brush it on your tank and side covers to make a very cool looking finish.
it is very durable and cheaper than most spray paints.
it also helps to sprinkle a little sand on it while it is wet on the tank to make it a non-slip surface for those that like to drive real peg scraping crazy.
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
- fonZee
- gas
20 Apr 2006 00:03
This one is settled for me, thanks guys.
- kx_125_pilot
21 Apr 2006 09:39
jtmcculloch wrote:
what kind of a finish? and where did you get that idea??
- waterman
21 Apr 2006 09:59
Quick question, how hard is it (generally) to remove the old boots. Mine are old and probably have never had any moron superglueing them on--how hard have you found them to be coming off?
- kx_125_pilot
21 Apr 2006 14:13
they should just pop off farely easily......might need a bit of help with a flat blad but, should't need a winch lol
