Feeler Gauges ???
- KZ1100 Bully
Can anyone tell me what gauges I will need to buy from Z1.
www.z1enterprises.com/default.aspx
Thanks
1983 Kawasaki KZ1100 Spectre D2
- z1kzonly
- Thank you received: 540
Look for a small set.
I have one that is .001 thru .012.
Thin, smaller to handle than a bigger set.
- Old Man Rock
- Thank you received: 225
Shims are sold in metric units thus no conversions...
Also as in mine set, .o5mm is the smallest size but have found where I wish I had some thinner such as .01 - .04mm... This way I can measure to the thinnest/thickest degree of accuracies by doubling up different blades...
Also, a digital caliper comes in handy as well....
Example, if I go to the next shim size places me at .15/.16mm... Close to maximum but in measuring some older shims that are marked as the next size but actually measure in slightly thinner due to old age/wear... golden!
.03/.04 to .15mm should cover the full range required...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
- Thank you received: 337
Conversions are easy if you remember that 1mm is about .040", so:
0.050mm is .002"
0.1mm is .004"
0.15mm is .006"
0.2mm is .008"
etc
- RonKZ650
- Thank you received: 240
- bountyhunter
.001"
.0015"
.002"
.0025"
I can measure all gaps to an accuracy of ONE HALF thousandth between .001" and .0045" by combining two gauges.
- KZ1100 Bully
You'll need the shim removal tool. Get that at Z1. For feeler gauges all you need is .05,.10,.15,.20mm. No need to waste time and effort on gauges that aren't in .05mm increments. This I've said many times over the years and most guys still prefer to measure with 600 different feelers. Yes I have .05235mm clearance using 600 feelers? Does you absolutely no good as shims come in .05mm increments, so measure in .05mm increments.
I already have the removal tool, was not sure on the gauges to get.
Thanks to all for the help.
- stonemaster
- Visitor
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- wargoth
Any brand of thickness gauge will work just fine. I like the craftsman (also should be the same for HD Husky) ones, cause when they get rusty, just take it back for a free replacement. They are supposed to be rust proof after all.
I like the round wire ones, they make a more accurate reading, but can be easily bent and require a large-ish size surface to work with. Not very good for screw/locknut type of adjustable rocker arms.
