KZ750 H2 Exhaust Headers 2 & 3
- Tommotbird
21 Oct 2010 00:17 #407908
by Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
KZ750 H2 Exhaust Headers 2 & 3 was created by Tommotbird
Can anyone tell me the difference between exhaust headers 2 & 3 as they look to be the same. They have different part numbers but are the interchangeable.
Thanks
Tommotbird
Thanks
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- Tommotbird
22 Oct 2010 12:37 #408281
by Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Replied by Tommotbird on topic KZ750 H2 Exhaust Headers 2 & 3
Anyideas Guys?
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- JMKZHI
- Thank you received: 48
22 Oct 2010 18:04 - 22 Oct 2010 18:06 #408342
by JMKZHI
Replied by JMKZHI on topic KZ750 H2 Exhaust Headers 2 & 3
I've often wondered about that. I believe there's a mark or number on them to indicate which one goes where. If I can find the time sometime this weekend, I'll check a couple of NOS pipes that I've got to see if I can determine if there's any difference. The pipes are the same as the ones on your bike.
Last edit: 22 Oct 2010 18:06 by JMKZHI.
- JMKZHI
22 Oct 2010 18:23 #408348
by JMKZHI
Well, I just compared them & they look virtually identical. Each one is stamped w KHI E005.
One has the number 2 stamped into it; the other one is stamped w a 3.
My only guess from eyeballing them is that maybe the flanged tips are slightly angled... just a guess & not really sure.
If I needed a header pipe, I would go ahead & use a #2 in the #3 position (or vice versa). If need be, I'd find a way to seal the exhaust port if one new copper crush gasket didn't get the job done.
- Tommotbird
23 Oct 2010 02:42 #408411
by Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Just checked in my Clymer manual and it says "Do not mix up the No2 (left) and No3 (right) exhaust pipes. Each has an identifying number.
However they still look virtually the same to me. Maybe all will be revealed when I try to fit the system. (I have two brand new No3's.
Tommotbird
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
