- Thank you received: 1
cross pipe section on stock exhausts
- lobstermobster
19 Oct 2010 22:07 #407692
by lobstermobster
1981 kz650 w/ flux capacitor
cross pipe section on stock exhausts was created by lobstermobster
are they necessary? all the aftermarket 2-1s I have seen do not have this setup. would it be ok to cut it off and patch up the 2-1s? pros, cons?
- bountyhunter
- Thank you received: 337
19 Oct 2010 22:17 - 19 Oct 2010 22:18 #407694
by bountyhunter
Replied by bountyhunter on topic cross pipe section on stock exhausts
The cross pipe on the stock dual pipe setups increases low RPM torque. You can run without it if you have to.
Last edit: 19 Oct 2010 22:18 by bountyhunter.
- JMKZHI
- Thank you received: 48
20 Oct 2010 04:39 #407709
by JMKZHI
Replied by JMKZHI on topic cross pipe section on stock exhausts
If you'll look at the stock exhaust system, you'll see that the pipes are rather narrow after the cross-over pipe. By removing & plugging the cross-over you'll reduce the exhaust outlet by half.
