valve question
- morhaven
I took the head off, first time doing this on a bike.
How can I test if my valves a stuck? bike has been sitting for 20 + years. I should of done a leak down test first or checked the clearances firt. but since I am new a wanted to look at the internal components to learn.
So head is off, I can;t push on the valves as It requires something like 300 psi to force it down,,anyone have another tip? Visually they do not look bent either. just carboned up.
- RonKZ650
- Thank you received: 240
- Thank you received: 2829
I don't get it. Before you pulled the head Steell, RonKZ650, and Larrycavan each advised you how to test if the valves were stuck by checking the valve clearances . Was there some reason you completely ignored their advice?
Again, I don't understand. Before you pulled the head Patton advised you to do a leakdown test, but now you ask if you should have done one.
Is there some reason you ask questions, ignore the advice, then ask the same questions after it's too late to follow the advice? Do you perhaps think these folks, who have tons of experience are pulling your leg when they offer good advice? Ed
- sm0kinace
There was also a lot of other advice in there too, including advice to pull the head near the beginning. I don't see why you are getting so bent out of shape, the general consensus is bent valves, and the second quote up there isn't even a question, more of an afterthought. But it really doesn't matter, because at this point simply doing the gas trick should reveal if there are major problems with the valves. It's not too late for anything.
Morhaven, you should get a manual for your motor. Please forgive me if I've misinterpreted this, but it doesn't sound as though you have a lot of intimate experience with motors, and a book will help you with some basic troubleshooting techniques [some will even tell you the why's and wherefore's of them], and how things should go together. I completely understand wanting to tear in and learn, but you kinda need to understand how things work right to figure out what's wrong when it's not right.
So, along with checking valve sealing, since you've got the head off, how do the pistons look? Do they have any marks, gouges, or dings that would indicate being hit by a valve?
1978 KZ650
Ichyta, KS
- larrycavan
- Visitor
There might not have been any need to tear the motor down.
The point of the advice was to determine that and hopefully keep costs down.
- Old Man Rock
- Thank you received: 225
Since you already have the head off... send it to one of several vendors listed on KZR such as Larry, Pit Stop, APE even a recommended local shop in your area etc....
Pending what your doing on this build, Stock compared to Performance, have a valve job accomplished regardless...
Prices will and can vary pending minor rebuild or complete rebuild with Port & Polish... If installing performance cam, (P&P) is highly recommended for increased air flow to truly benefit the cams performances.
Those seals, springs, valves, guides etc... have been in there for a long time and no telling what occurred way back when or what condition they truly are in without complete dis-assembly...
Considering the head gasket alone is $50, get it done correctly by a pro and have it checked out by someone who knows WTF they are doing.... If in doubt, Kibble White valves are ~ $20 each... Z1 has OEM valves... New OEM seals, others claim Viton seals but new for sure....
Best advice any of us can give you for this is one of those areas where w/out proper tools and knowledge a perfectly good head can and will become a perfectly good door stop....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- BSKZ650
- Thank you received: 14
if not bore it out and new pistons.
check everything and replace the rubber parts and timing chain.
if your going to do it, do it right one time only
77 ltd1000, current rider
76 kz900, just waiting
- sm0kinace
my 10cents, since you have the head off, get a complete valve job done on it, also, mic the cyls, to see if they are still in tollerance, if so new rings and hone the cyls.
+ absolutely all of this. cam and crank runout checks would be a good idea too.
very necessary, good advice.
1978 KZ650
Ichyta, KS
