Oil Pressure Fitting.
  • kimsmith4807
  • Topic Author
16 Oct 2010 17:47 #407079 by kimsmith4807
Oil Pressure Fitting. was created by kimsmith4807
My KZ1000-K1 came with a Derale oil cooler. I have removed the cooler and now have to deal with the two barbed fittings on the oil pressure fitting. Is this fitting an aftermarket piece that is required for use with the cooler or is it factory? It doesn't look like the one in the parts diagram. If it is factory, do I simply plug the holes where the barb fittings are?
1981 KZ1000-K1 LTD
  • kimsmith4807
  • Topic Author
26 Oct 2010 14:46 #409212 by kimsmith4807
Replied by kimsmith4807 on topic Oil Pressure Fitting.
Answered my own post but I had to buy the factory fitting to do it though. The factory fitting is similiar in style to the aftermarket one but has a passage between the two ports, allowing oil to flow up to the oil pressure switch, through the fitting and continuing on to the top end. When I get the motor back from PSP I will have a pressure fitting that is suited for use with an oil cooler that someone could have if interested.
1981 KZ1000-K1 LTD
  • Kawickrice
30 Oct 2010 19:31 #410014 by Kawickrice
Replied by Kawickrice on topic Oil Pressure Fitting.
Do you have both pieces for the oil cooler connections? If so shoot a PM to me.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
