- Thank you received: 114
Tip for degreeing cams
- larrycavan
- Visitor
- racer54
- racer54
- larrycavan
- Visitor
The less drag on everything the easier it goes.
I often assemble one piston with just the top ring and no wristpin circlips. Assemble the head with light springs [hardware store] and valves in same end cylinder that piston is in.
Degree the cams, then yank it back apart and assemble normally.
Keep your math simple.
Large number - small number + 180 /2 = lobe center value
Make sure sprockets spin smoothly on cam sprocket boss before you bolt them in.
Install all three bolts but fully tighten only the bolts that coincide with the valve cover surface at installation position. One on each cam. Put a dot on that bolt with a paint stick so you don't get confused.
When needing to make an adjustment, if there's any issue with the cam not wanting to freewheel while the crank is moved, a screwdriver tip placed between the loosened bolt head and valve cover surface cures that problem.
I do the clean and loctite after I pull the cams back out. One bolt at a time, starting with either of the bolts that does not have the paint dot...DON'T do that one till last :laugh: or you'll be starting over....
- kopcicle
- Thank you received: 4
"There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block..."
- dr_bowtie
Some time ago I needed to move the sprockets around on a 903 engine so a machinist friend of my fathers slotted and relived the area around the attaching bolts . Old Mr Bridgeman was a unique talent . It may not have been necessary but when I had the parts returned to me he also handed me a small handful of what looked like half moon metal bits . Ok so I ask wth are these for as he patiently and with only moderate disgust explains that they are to fill either side of the void caused by slotting the sprocket on at least one of the bolts to prevent the cam sprocket from rotating . Yes I had to chase after one or two before I was bright enough to use the procedure Larry outlined . I don't know that there is the possibility of a slotted cam sprocket moving . I never allowed mine to
offset bushings....we use those in car engines too...
once you degree once or twice it becomes very easy...
never done a bike engine but many, many car engines...
- nads.com
- Thank you received: 20
Just wondering why u would assemble one piston, one ring, and then take it apart again. Is the base gasket in? The head gasket? And is it torqued? Just seems like alot of work for no real gain in time savings or functionality. The motor doesn't drag much anyway, what ya got the spark plugs in too? :woohoo: That's gonna hurt. But hey I'm just askin., you'll probably be on here explaining it all with good reasons behind it all. Just that a new guy is going to follow your steps and ..... Guess he'll know after he's done what works well and what doesn't . Latex gloves please? The mask? Thank you Assistant. Omar the assistant has issues, only other applicant was Nads.com whose screwed his head up, and is completely nuts. The background music is playing. Willy won't go home. Ear plugs, body suit and decon chamber all ready. 4 oclock in the morning. Time for one more rotation before dawn. Such fun is life, just need better glasses, better gloves, better assistant. Damn OMAR. Where the heck did he go? Soon as the gloves are out he gone. What's matter with that guy?Getting the dial indicator tip to track is the most frustrating part.
