Engine popping
- customkz1000
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- bikerjim
- 1986 T-type Regal
Would air pods, a header and larger jets in my carbs cause engine problems for a stock kz 1000 engine?:blink:
Is the pop on deceleration? Some members (including me) have reported that a loose header clamp can cause a pop. You might be sure that yours' are torqued properly, but be careful. Those little studs can strip/break easily.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
- bountyhunter
- Thank you received: 337
- Thank you received: 2829
Pods and headers not only run more air through they change the flow characteristics which means the needle taper is no longer matched to the engine flow. IMHO, pods are 10000X more trouble than they are worth.
+1
- customkz1000
- bountyhunter
I would go back to the stock air box and dial the jets and needles in from there.
Careful there Bountyhunter; Trianglelaguna will call you names for making such a suggestion. :laugh:
