- Thank you received: 540
Z1 Aftermarket Valve Seals
- z1kzonly
But, what is the best valve guide seal for For Z1-KZ900?
Limited use, low milage, hotrod engine.
Viton, stock OEM, Versah?
Of course, always want the cheaper ones!
Thanks.
- z1kzonly
$1.39 a piece. I'll buy 10, I have ripped them in the past trying to get over valve guide.
- bountyhunter
- Thank you received: 337
- z1kzonly
- otakar
VITON is orders of magnitude better material for valve seals than standard butyl rubber. It stands up to temperature much better and retains it's elasticity. Definitely worth the extra $ if they are available.
+1 I agree. Todays technology Viton is the way to go . I bought them in a bulk of 50 for my bike. I buy mine from Joe Hooper at Pit Stop Performance.
www.pitstopperformance.com/kawasaki-z1-k...on-set-of-eight-p-31
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- hardr0ck68
- Who put the what in the where?
Thanks, I did use a set of them a couple of years ago on a de-stroked 750cc midget car Z1 engine.
What was the reason for de-stroking? How did/does the 2 valve head perform at higher RPM's? What was the motor's performance like?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- z1kzonly
They cut the whole tranny of the back of the block and ran it with an in amd out direct drive. Being air cooled the KZ faded.
Now they run moderend liquid cooled engines GSXR's etc.
- hardr0ck68
It is just begging to be put into a bike I think :laugh:
1977 kz650 c1
- z1kzonly
Like a high gear only nitro bike.
A belt from the crank to the torq converter.
The more you twist the throttle the faster you go.
They have them torq converters that handle up to 300 HP.
