- Thank you received: 10
Ticking Valve at idle on cylinders 3 or 4...
- Kitten Tooth
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- larrycavan
- Visitor
So i found that i have a ticking valve on either cylinder 3 or 4.. It seems to only tick when the motor is warmed up and been running for a few minutes. Its a small tick (almost sounds like its low on oil but its not).. Like i have said 1000 times before, it runs like a monster and i have good compression. Im worried though because i called a good mechanic i know that specializes in the older KZ bikes and he said that if it gets bad enough it could "spit a shim" meaning that it could fire the shim out and destroy the head. I plan on driving this thing some more before it gets completely cold out there. i just want some peace of mind:D He said that if the the adjustment gets too far off that the shim will start to float in there at around 6000RPM and at that point it could shoot out. Do you guys think i should get in there and just do the job now or do you think it can wait till the storage period when i totally overhaul it?
Thanks guys,
KT
Tim,
Would need one of your videos to hear what it sounds like.
If you want to check the valves and need a valve cover gasket....pm me your mailing address and I'll send one off to you no charge. If you tell me what size shim you need, I'll send one of those also...
Larry C
- RonKZ650
- Thank you received: 240
- Thank you received: 2098
- Kitten Tooth
Once again, Thanks Larry!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
