- Thank you received: 2098
Disabling exhaust air injection system
Am thinking both U.S. and Canadian models use the same cylinder head, whereby a U.S. valve cover could be replaced with a Canadian valve cover (without issue of absent valves).
Thoughts?
- muddy1
- 1980 Kz1000 LTD B4
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
I would think that you could ditch the reeds/valves, I did, the (2) hole's in the valve cover itself can be blocked off, via a threaded bolt. It keeps any carbon if any from making the underside of your shiny aluminum (reads APE) covers dirty...
the (2) hole's in the valve cover itself can be blocked off, via a threaded bolt. --- not understanding what holes. Do the holes show in this pic?
- muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
the holes do not show in the picture, it is tough to see from all the carbon buildup, but the hole is almost tunnel like, it's at an angle (man I hope you are not messing with me :laugh: )
Nope, no messing --- and thanks for the responses.
The earlier pic is from an ebay listing.
Just found this more detailed pic showing the holes;
And a diagram of the CAS (Clean Air System), shown in the following post.
Might be incorrect about the Canadian model having same head as U.S. model, but thinking kawasaki.com says they're the same.
Perhaps the Canadian model heads also have the air passages (unused) from the valve cover to the exhaust valves.
[Click on image to enlarge view.]
...Perhaps the Canadian model heads also have the air passages (unused) from the valve cover to the exhaust valves....
