76 KZ650
  • bloglos
  • bloglos's Avatar Topic Author
76 KZ650
14 Oct 2010 09:56
#406590
I have a chance to buy a 76 KZ650 for next to nothing. It looks to be in great physical shape, but the big problem is one of the spark plug threads is stripped in the engine. How big of a deal is this? Should I avoid this thing? I already have a 78 KZ650 C2 which is running great. Worst case, can I use this as a parts bike for my C2? or are they enough differences that I shouldn't bother.
I would love to use this second bike as a means to learn more about bikes and ultimately get it running but I'm concerned about the stripped thread.
78 KZ650 C2 - Runner
77 KZ650 B1 - Project
  • DoubleDub
  • DoubleDub's Avatar
Re: 76 KZ650
14 Oct 2010 10:05
#406594
A competent shop can install an insert with the head on. Pretty cheap and can be reliable given the right person installing and the right insert.
  • loudhvx
  • loudhvx's Avatar
Re: 76 KZ650
14 Oct 2010 10:08 - 14 Oct 2010 10:09
#406595
It may have been built in 76, but I think it has to be a 1977 model. C1 or B1.
I don't think Kaw has a 1976 model KZ650.
Last edit: 14 Oct 2010 10:09 by loudhvx.
  • DoubleDub
Re: 76 KZ650
14 Oct 2010 10:10
#406597
Hmm...missed that - my bad.
If you're looking to do it yourself, an insert isn't difficult to do, but for a first time it might be difficult to get it right. The Timeserts are probably the best ones to use for this as they have a tool that assists you in getting the tap straight for the inserts.
A stripped spark plug hole is not uncommon or a huge deal, although some recommend removing the head to do it. Is that all that is wrong with the bike?
Re: 76 KZ650
14 Oct 2010 10:11 - 14 Oct 2010 10:11
#406598
Stripped spark plug hole may be repaired with Heli Coil or Time-Sert.
Is it for certain that the threads are actually stripped as opposed to being cross-threaded?
When cross-threaded, there's sometimes sufficient metal remaining to re-thread the hole.
A reverse tap is a handy tool for this, which re-threads starting from the deep end of the hole where the threads are usually still intact, and without needing to remove the head.
Good Fortune! :)
Last edit: 14 Oct 2010 10:11 by Patton.
  • bloglos
Re: 76 KZ650
14 Oct 2010 10:40
#406602
The carbs need cleaning and the rubber boots look like they need replacing, the bike has been sitting for a looong time, but was parked because of the stripped thread. I'm sure I'll find other things that need fixing or replacing, but the bike looks to be in really nice shape. He's asking so little that I think I'd be crazy to not buy it, even for a parts bike (Assuming I could use it as a parts bike for my C2)
  • BSKZ650
  • BSKZ650's Avatar
Re: 76 KZ650
14 Oct 2010 10:46
#406605
the repair is simple as stated before, couple of questions, has it been outside where water and such could have got into the open cyl? also does the motor turn over?
but then again, it could be a good parts bike still even if the motor is locked up.
77 ltd1000, current rider
76 kz900, just waiting
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 76 KZ650
14 Oct 2010 17:01
#406663
The '77 ('76) does have a different charging system than your '78, but most of the rest can be good for spares.
You can also convert to the '77's charging system if need be.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Injected
  • Injected's Avatar
Re: 76 KZ650
14 Oct 2010 17:06 - 14 Oct 2010 17:07
#406665
If its been sitting in a garage or barn somewhere the brakes will be junk for sure... I just bought one like that and it had been under a blue tarp for at least 10 years.
I thought the brakes were OK until I stripped everything apart and found all the seals and pistons needed replaced due to moisture and rust in the brake fluid.
At first stuff looks OK... then you dig deeper and really have a hard look and it becomes clear that a lot of stuff is un-useable... a lot of the chrome was so far gone it had pitched - it was cheaper buying good used replacement parts than rechroming!
By no means am I trying to persuade you not to buy it - parts are getting rare used with parts every day being dropped from service by Kawasaki, so I would say buy it at least for a parts bike. If the chrome is good and straight buy it for sure !!!
There is no problem with parts compatibility between those models except for the brakes and wheels are different (between B and C) and if a 77 some electrical.
1978 KZ650B2 modified project
Last edit: 14 Oct 2010 17:07 by Injected.
