Cam caps
  • kawa
  • kawa's Avatar Topic Author
Cam caps
13 Oct 2010 22:58
#406533
How do you get those cam covers off?
  • stonemaster
  • stonemaster's Avatar
Re: Cam caps
14 Oct 2010 00:44
#406539
tap with rubber hammer
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Cam caps
14 Oct 2010 03:20
#406541
What type of motorcycle?...cam caps, cam cap cover, or cam cover?...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • kz1k
  • kz1k's Avatar
  • You Cant Fix Stupid!
Re: Cam caps
14 Oct 2010 05:25
#406557
pick up the motor, turn it upside down and shake it.
1978 KZ1000A2
Re: Cam caps
14 Oct 2010 06:10
#406559
:unsure: Motorcycle year and model?
A posted message including information about bike year and model will likely elicit better responses.
It's easy to put information in your signature so it will automatically appear in posted messages.
When done, the signature showing information will appear in all posts, past and future.
And the information may be changed as often as desired.
Here's how to do it:
Click here > =http://kzrider.com/index.php?option=com_kunena&Itemid=116&func=view&catid=8&id=382004]Add Signature
Good Fortune! :)
Re: Cam caps
14 Oct 2010 06:21
#406561
  • kawa
Re: Cam caps
14 Oct 2010 09:17
#406583
I tried shaking it. No go. The swamie is right 1980 KZ 1000 shaft. I am talking about the black half moon shaped plastic on the head. It is where my valve cover gasket leaked and I don't want to do it twice. My plan was to seal them with High temp gasket.
Re: Cam caps
14 Oct 2010 09:45 - 14 Oct 2010 09:47
#406588
Here's what the plugs look like.
Click > www.z1enterprises.com/detail.aspx?ID=104
The existing plugs are likely glued in place and may be pulled out of their slots.
Clean the slots. And clean the plugs if new plugs aren't being fitted along with the new gasket. But it's better to use new plugs.
Whether new or used, smear a thin film of silicone around the plugs and immediately install them so the silicone will help seal against oil leakage around the plugs.
Just before installing the new gasket, add a thin film of silicone to the flat area of the plugs.
The cam cover and head mating surfaces should be perfectly clean and free of any stuck on residual old gasket material.
I install the gasket bone dry, and have zero leakage.
Good Fortune! :)
Last edit: 14 Oct 2010 09:47 by Patton.
  • kawa
Re: Cam caps
14 Oct 2010 10:03
#406592
Thanks
