79 kz1000 chain tensioner need to remove topend
- morhaven
12 Oct 2010 10:46 #406138
by morhaven
79 kz1000 chain tensioner need to remove topend was created by morhaven
Hello again, I have an 79 kz 1000 st.
Seems my exhaust cam is in 180, and I suspect bent valves. since I have zero compression on all 4 Cylinders.
Now before I take off top end, I am looking online and it seems I need to replace the chain tensioner bold with a diffent one, to lock it in place.
The part online is saying Bolt #110B0616... can I find this bolt somewhere already on the bike?
If I can find this bolt then I just replace it with the one that was already in the Tensioner, but since its longer it will lock it?
this is my first time taking off a top end, so any help/guidance is always appreciated.
thanks again.
thanks again.
- muddy1
- 1980 Kz1000 LTD B4
12 Oct 2010 14:56 #406181
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic 79 kz1000 chain tensioner need to remove topend
I dont think it would hurt anything by removing the entire cam chain tensioner, there should be no need for a different bolt. It appears someone else put your cams back in?
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- morhaven
12 Oct 2010 16:02 #406214
by morhaven
Replied by morhaven on topic 79 kz1000 chain tensioner need to remove topend
I picked up this bike for free, seems cam was put in incorrect.
In the service manual it say before removing the cams to rotate, to lock the chain tensioner.
I assume this is to no get any lose on the chain when i add slack to the top?
- DFIGPZ
- Thank you received: 122
12 Oct 2010 16:34 #406220
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic 79 kz1000 chain tensioner need to remove topend
The bolt is located on the side of tensioner it is seen in the picture you provided. now to remove the tensioner you do not have to do anything with the bolt,but to install the tensioner you loosen the bolt push the plunger back and tighten bolt just enough to lock the plunger in, then install the tensioner after cams properly timed then unlock the side bolt to release plunger then tighten bolt up you are finished.
1984 750 Turbo
- morhaven
12 Oct 2010 17:14 #406229
by morhaven
thanks for the info about how to re-install.But all i want to do is remove the top end to check the valves and rotate the cam to correct position. In the manual it says to LOCK the chain tensioner with a different bolt?
does this make any sense?
its an automatic tensioner
- RonKZ650
- Thank you received: 240
13 Oct 2010 07:05 #406315
by RonKZ650
Replied by RonKZ650 on topic 79 kz1000 chain tensioner need to remove topend
All you do to lock the tensioner is use a long 6mm bolt. You can use a valve cover bolt or any other common 6mm bolt you can find. Length is not important as long as it's long enough to contact the rod in the tensioner to hold it. Don't remove the tensioner which won't do you any good as if you do this or remove the cams without first locking it, the rod will extend and it will have to be disassembled and retracted in the bore before use.
- Tony
- Thank you received: 13
13 Oct 2010 07:47 #406320
by Tony
Replied by Tony on topic 79 kz1000 chain tensioner need to remove topend
If your your timing is correct EXCEPT your exhaust cam is 180 degrees out, you will not have any bent valves. Reinstall the exhaust cam properly, double check your timing , then do another compression check.
- Tony
13 Oct 2010 07:57 #406321
by Tony
When you do this work to your engine make sure your bike is level. Either use your center stand or block up your side stand. If it's not level your camchain might not align properly with the necessary gears causing serious problems.
