Bike won't run under load
  • prochlea
  • prochlea's Avatar Topic Author
10 Oct 2010 14:26
#405729
I have a 78 KZ650 that was running pretty well until recently. It would take a little while to warm up, but once it was warm, it would run pretty good - the only issue was a little backfiring under deceleration. Yesterday I took it out, and it was running good while in neutral, very responsive to the throttle... But when I took off, it would need alot of throttle to get going, and as soon as I let the clutch completely out the engine would really struggle. I could ride it in first gear up to about 15 mph, but it would sputter in 2nd, and die in 3rd. Does anyone have an idea of where I should start looking?
Re: Bike won't run under load
10 Oct 2010 14:30
#405732
Please give a little more background. Is the engine, airbox, exhaust, points, etc. stock? When was the last time it was tuned up? Has it been used on a regular basis? Does the inside of the fuel tank show any rust? Does it have a fuel filter? Is maintenance (oil changes, etc.) performed on a regular basis? Thanks, Ed
  • prochlea
10 Oct 2010 14:37
#405733
I just changed the oil. It gets ridden alot. I just got the bike last year, and I haven't had it tuned up. The air filters are the 4 pods, not the stock air box, but everything else is stock. I don't see any rust inside the fuel tank, but I haven't changed the fuel filter. That's a good idea - the last time I had the bike out and it was running well, I almost ran it out of gas, so it's possible that I sucked some sediment that was in the bottom of the tank into the fuel filter. Any other ideas?
  • MFolks
  • MFolks's Avatar
10 Oct 2010 15:03
#405748
Checked compression? Checked valve clearances? Air filter not clogged? Good spark? Changed sparkplugs with proper gap?
Checked mechanical ignition advancer for proper operation?(it's behind a CD sized cover on right side of engine and should return to position at rest when twisted by hand with engine off).
  • JR
  • JR's Avatar
10 Oct 2010 15:57
#405756
Is it firing on all cylinders ?
Fire it up. Give it a minute to get warm and then spit or spray water on the exhaust header where it exits the motor. If the cylinder is firing the water sould sizzle right off.
