cam to crank timing
  • skemp101
  • skemp101's Avatar Topic Author
cam to crank timing
08 Oct 2010 20:14
#405363
I have an 1983 gpz 750 original owner, I bored out the engine .030 over. Valve job to head and new wiseco pistons and rings. I had low compression after the rebuild, about 90lbs in all 4 cyl. Moving the cam a tooth or 2 would change compression a little. Anyone know the trick to setting the cams to crank position. it was runnimg rough at one point. I tore it down again to inspect pistons and valves. everything looks great. it should have 150 psi in cyl. Thanks for any input.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: cam to crank timing
08 Oct 2010 20:35
#405380
have you got a manual? B)
09 Oct 2010 07:05
#405443
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationskemp101 wrote:
Hello, Scott, and WELCOME to KZR! :cheer:
If interested, these manuals are available.
Price is right, but time is short, on the first one.
The 2nd comes highly recommended and is probably one of the best manuals available.
Meanwhile, a leakdown test might prove helpful with regard to the lowish compression.
Good Fortune! :)
  • JR
  • JR's Avatar
09 Oct 2010 19:04
#405576
You can download the full shop manual here kz.mbsween.com/manual.html
See pages 54, 55 and 56 of the manual. The bottom of page 55 has a diagram of where the cam sprocket should line up when 1 and 4 are at TDC.
  • skemp101
09 Nov 2010 09:18
#411841
Thanks for the help I think it is dialed in now, I am almost redy to get it started!!:
